JCW JCW factory height & spring rates for Clubman
None, as the Factory JCW comes with the exact same suspension as every other car. If you order the dealer installed "JCW Sport Suspension" then its 10mm lower and should be a lot stiffer/sportier. The standard suspension is entirely too soft. Had I known that Mini appealed to the masses as much as they did compared to the Gen1 cars I would have ordered the JCW suspension immediately, or at least the sport suspension.
After x-mass I will be installing the full JCW sport suspension and can't wait to get back to the go-cart sporty feeling my Gen1 car had.
Just a clarification - an "S" or any other MINI with the sports suspension package is different from a JCW with a stock suspension. The optional sports suspension (I assume that is what hamptup was referring to) comes with stiffer springs, shocks and larger front and rear sway bars than the stock setup has. This does not lower the car, but it is a great handling improvement. The optional JCW sports suspension takes all of that one step further as k_h_d said.
PelicanParts.com
Aug 4, 2015 02:45 PM
