JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW jcw gp 2 diffuser
Old Mar 8, 2014 | 06:30 AM
  #526
champ198's Avatar
champ198
I just installed the diffuser on my Coupe. It took two hours to install. 1 hour and 45 minutes to take out and put back in the two small screws on the sides and 15 minutes or less for the rest.
Do I need the two clips and screws at the most forward edge of each of the plates (appears to attach to the existing plastic panels under the car)? I went to the auto parts store and got a couple of trim clips thinking I was missing them. The fit is extremely tight with the plate attached to the bumper and there are gaps where the panels and diffuser (bumper) meet. If I "undo" the attachment to the existing underbody panels, it may allow for a better fit. Do I keep the diffuser panels attached to the underbody panels, or keep it?
Thanks for any feedback.
Pic of gap with the panel fit. Normal?
Old Mar 8, 2014 | 07:58 AM
  #527
cactusjk's Avatar
cactusjk
You should be able to close the gap by loosening the metal brackets, getting everything positioned then finally tightening them s the last step. Lots of discussion on that in this post. Also, there are clips/screws that connect the front of the panels to the existing underbody panels. I got mine from Mini. Those part numbers should be listed in here.
Old Mar 9, 2014 | 09:48 PM
  #528
tigerwong58's Avatar
tigerwong58
I actually did not install the 2 screws on the end that connects to the factory belly plastic and it fit better and holds fine. Take off those 2 and see what happens.
Old Mar 10, 2014 | 01:39 AM
  #529
ATCQL's Avatar
ATCQL
I had the diffuser painted to match body color,and am happy with the results.Check out my gallery for pictures. Q
Old Mar 10, 2014 | 05:08 AM
  #530
Gil-galad's Avatar
Gil-galad
Nicely done! I like the way you left the undersides black; it provides an interesting contrast with the painted surfaces.
I also like the fact that it's unique. It's great having a relatively understated and classy mod (i.e., not ostentatious like some MINIs you see) that at the same time allows you to stand out from the pack.
Old Mar 10, 2014 | 06:45 AM
  #531
That's pretty awesome painted. +1 like how you kept the underside black.
Old Mar 30, 2015 | 11:16 AM
  #532
komet155's Avatar
komet155
What is that thing?
There's a black plastic cover on the lower strut mount bolt on the left side of this car (viewable immediately to the left of the jack stand). The other side does not have this cover.
I just noticed my 2013 "Justa" has one of these covers on only the right side. Am I supposed to have one on each side or is this something that's attached to the headlamp leveling sensor (I have xenon headlights).
Thanks!
Originally Posted by Btwyx
Old Mar 30, 2015 | 11:35 AM
  #533
Seen this a couple times, suppose to be on both side, sometimes they fall off when bumped or it was a production line miss.
http://www.ecstuning.com/Search/SiteSearch/33506851235/
Old Mar 30, 2015 | 11:42 AM
  #534
komet155's Avatar
komet155
Thanks! I'm hoping to get it replaced when I go for my next service (I'm still under warranty). Otherwise, I know where I'll be getting it if I need to buy it myself.
Old Mar 30, 2015 | 02:11 PM
  #535
Welcome.
Old Feb 15, 2021 | 01:37 PM
  #536
Just an update, we just landed a bunch of these in stock w/ free shipping. On sale for a shot time.
https://www.ecstuning.com/b-genuine-...51747330558kt/
Old Apr 20, 2021 | 12:05 PM
  #537
wtorres141's Avatar
wtorres141
Got mine from ECS and am super happy with the look.
Old Apr 21, 2021 | 02:46 PM
  #538
Very nice. Completes the back end.
Old Dec 5, 2023 | 11:58 AM
  #539
Just an update we have some ECS GP2 parts in gloss black! 51747330558
https://www.northamericanmotoring.co...-body-kit.html
Old Dec 6, 2023 | 08:50 PM
  #540
wtorres141's Avatar
wtorres141
Only euro side arches?
I have a nice pair of the blacked out markers. I'd have to figure out how to disable w/o generating a bulb warning.
Am kind of fond of how my markers look. Any chance you wound get the gloss black set with markers?
Old Dec 7, 2023 | 07:14 AM
  #541
Not at this point. After looking at the markers not being their are so much cleaner. Also we are the only ones who have them, most of the world outside of the USA does not have them so now those people have factory look gloss black.
I guess you could cut those and install the markers, using the old ones as a template and reuse the plastic mounts that are molded in.
LaurelEdition
GP Talk
25
Apr 4, 2013 05:16 PM
PinoyMini
Jan 13, 2012 03:43 PM
JCW4me
GP Talk (2006)
23
Aug 13, 2008 08:44 AM
domc
May 26, 2006 06:17 PM
