JCW GarageInterested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
Bought a set a month ago for our 06 MCS replacing the doe runflats-195/55/R16. The ride and lower sound levels are a night and day improvement!! They do have a 5yr/60K warranty. Handling was not a crisp as the stiff side walled runflats but still very acceptable for an old man. Since these are LRR (low rolling resistance)tires, I have yet to do a mileage improvement check. The tread and sidewall appearance are OK. I shopped online and finally went to Quick Lane. They matched the best online price, were 40% less on the install and offered free lifetime rotation and balancing. And to top it off they offer a $100 rebate if purchased by 31 August. Saved nearly $200 over the online stores with the rebate, install and lifetime rotate/balance. Bottom line--couldn't pass this deal up. Good luck.
Tracking is fine and the grooved pavement sofar poses no problems. As mentioned the ride is a vast improvement over the run flats. I now don't have to brace and cringe going over any type of bumps and I can hear the radio without blasting out my wife.
The installer inflated them to 35psi. Searched around and found a consensus of 33-35 psi. So I split the difference and have them at 34. I am open to suggestions from those who are more experienced.
