JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Black tail pipes, running to rich?
Old Oct 14, 2008 | 05:38 PM
seebobgo's Avatar
seebobgo
Any one else here with the stage 1 kit, experiencing the same thing?
Old Oct 14, 2008 | 08:59 PM
samroberto's Avatar
samroberto
A little bit of sut on the bottom part of the tip ... I have no idea if it's running too rich ?? ... They're not like, COVERED, I just figured a little black dirt was normal ...
hmm
and +subscribed
Old Oct 14, 2008 | 09:19 PM
morbius's Avatar
morbius
Dr. Morbius
My tail pipes have the same thing but so does my wife's stock MCS. I do notice that the JCW pipe tips will show the sut more than the original tips.
Old Oct 15, 2008 | 03:25 AM
edijak's Avatar
edijak
Before and After Stage I
Stock R56S had a lot of carbon on the pipes. After JCW Tuning Kit little to none. I originally asked MA about the carbon and they checked "mixture" and found no problems. "Mixture" OK? WTF?
Now, no carbon with the new exhaust and ECU. So, I guess all is well
Old Oct 15, 2008 | 06:34 AM
seebobgo's Avatar
seebobgo
Mine are coated big time. I'll call my worthless dealer today and see if they can plug it in. I wonder what the plugs look like? Thanks for the input!
Bishamon's Avatar
Bishamon
Mine had quite a bit of carbon both before and after having the JCW kit installed. I had hoped that the JCW tips would hide the carbon, but it's even more apparent. I considered painting the area inside the tips black with high-temp paint, but figured it would come off eventually.
Every stock R56 MCS I have seen has exhibited the same issue; mine is the only R56 MCS JCW I have seen in person.
Old Oct 15, 2008 | 10:28 AM
seebobgo's Avatar
seebobgo
I called the dealer and they said the more ethonal in fuel, the more carbon on the pipes. Kind of makes sence. I was using BP. He said try Shell, Texaco or Citgo. What fuel are you using?
Old Oct 15, 2008 | 10:34 AM
futuremini's Avatar
futuremini
Very good point. I am not using the ethanol blend either. The tailpipes are clean on mine except a little at the very bottom of the tips.
Old Oct 15, 2008 | 10:51 AM
scruffylooking's Avatar
scruffylooking
My stock 08 MCS was thickly coated on the bottom half of the exhaust tips with black soot. I wiped it off recently and I'll keep an eye on it. Maybe it was a break in thing...
Old Oct 15, 2008 | 10:58 AM
seebobgo's Avatar
seebobgo
It's the ethanol
Make tortilla's, not gas! Shell V power seems to be a top choise.
Old Oct 16, 2008 | 08:22 AM
Bishamon's Avatar
Bishamon
Originally Posted by seebobgo
Graet idea
I've only ever used Shell V Power since day one. I did a lot of research before filling up to find the best little-to-no ethanol solution after reading about previous generation MINIs with damaged fuel pumps.
Old Oct 16, 2008 | 01:36 PM
Crashton's Avatar
Crashton
Since this country switched from leaded fuel every car I have owned has had a black sooty exhaust. In the old days you could tell a good running car by it's light gray color in the tail pipes. Now with no lead it is soot city. I think your MINI is normal.
Old Oct 16, 2008 | 06:58 PM
seebobgo's Avatar
seebobgo
I think these are the good old days.
I filled up on Shell this morning and toped it off with some FI cleaner. High content ethonal is poison for the Mini. The girl is running better already. BP gas...the queen can keep it.
Old Oct 18, 2008 | 06:39 PM
magic08mini's Avatar
magic08mini
My MCS has run pig rich since way before I got the JCW kit.
Old Oct 28, 2008 | 05:10 PM
MotorMouth's Avatar
MotorMouth
or so you think. I bet a dyno and a AFR measurement would prove you wrong.
07+ MSCs run very lean. scary lean at lower rpms.
maytulip32
Aug 19, 2015 12:49 PM
Bennyboy
Aug 18, 2015 07:28 AM
Lt. Dan
Aug 10, 2015 08:23 AM
dyeLucky
Aug 7, 2015 07:10 AM
