JCW JCW Carbon Fiber Rear Door Handle Install?
Has anyone installed the JCW CF rear door handle them selfs? How hard is it? I hear the mirrors and hood scoop are not very difficult.
i would say the mirror and hoodscoop are harder than the boot handle... but they are not "hard." I find it easier to unscrew a screw than to pry snap connectors because i have a tendency to break those quite easily.
The only potential "gotcha" for installing the rear hatch handle is that some cars have more slack in the electrical wiring then others. On some cars, you can pull the wiring out enough so that the quick-disconnect plug is outside of the car's body, while other cars don't have as much slack, so you have to reach *inside* the body panel with either skinny fingers or needle-nose pliers to unplug the connection.
Other than that, the swap is trivially-easy.
So if I were to order this (and the bonnet scoop) from my dealer, does anyone know whether the parts would come with installation instructions?
hi guys, tried to install mine last wekened but seems there's something wrong with the wiring :(
after connecting the wires, seems the lock doesnt work...do i need to reprogram back or connect/reconnect the battery terminal as well???
How'd it go.
I'm about to install it. Did you get the lock working. Any tips to share?
marendt428
Aug 9, 2015 06:54 PM
