JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW CAI performance
Old May 27, 2007 | 11:06 AM
mini555's Avatar
mini555
JCW CAI performance
Is there any noticable/significant performance boost (and associated sound) with the JCW CAI below 4500 rpm (per JCW specs)???
Old May 27, 2007 | 03:09 PM
cooldaddy's Avatar
cooldaddy
noticable, only slightly. significant, no... if you want to get the most out of the JCW intake replace the filter with a foam version (althought the stock paper version isn't bad, just expensive) and remove the flap (will add a bit of noise "sooner")... just don't expect big changes...
Old May 27, 2007 | 03:11 PM
minimarks's Avatar
minimarks
Get it..You'll like it!
Old May 27, 2007 | 08:59 PM
Maxicooper's Avatar
Maxicooper
+1
Old May 28, 2007 | 04:41 AM
buzzsaw's Avatar
buzzsaw
It looks great under the bonnet and if you perform a flapectomy, it sound good and there is a bit of a push in performance in the lower rpms. IMO
Old May 28, 2007 | 07:02 AM
Bahamabart's Avatar
Bahamabart
I don't get the flap logic - to me it should be the inverse. It should be open and as you you accelerate it should close. As you gain speed the primary source of air should build and w/ the flap closed the air box should pressurize.
The open back to me comes in to play at low rpm or speed giving another source of air (short path to the filter/throttle body) so it doesn't have to suck it thru a straw so to speak.
Old May 28, 2007 | 11:58 AM
minimarks's Avatar
minimarks
Don't forget to remove the lower plug... Then just let the flap do it's thing...
Old May 28, 2007 | 05:09 PM
mini555's Avatar
mini555
Thanks for the feedback. I'm having a SS exhaust install in a couple weeks and was looking at doing the CAI at the same time...
Old May 28, 2007 | 07:44 PM
Scrumpy_Jack's Avatar
Scrumpy_Jack
I did this on my GP (replaced the stock filter with a K&N filter and removed the flap) and immediately noticed a difference in low end torque. The "pull" is much stronger across the entire power band. The increase in sound is great too!
Old May 30, 2007 | 06:13 PM
tc4653's Avatar
tc4653
Had mine installed today, picking up the car tomorrow. I'm ready to feel the difference.
Old May 31, 2007 | 06:39 AM
MINIFVR's Avatar
MINIFVR
Nice move- remove the main bottlenecks. Just curious, but which exhaust are you going with?
Old May 31, 2007 | 01:29 PM
Maskita's Avatar
Maskita
Is there any problem with just jamming the flap, so it stays open all the time? This would prevent the removal of the flap and it could be turned back to stock JCW at a seconds notice.
Old May 31, 2007 | 01:42 PM
Cactusflier's Avatar
Cactusflier
My JCW CAI's flap has a small metal lever that slides into a loop in the center of the flap. With the CAI in place in the car just put your hand into the opening where the flap is, find the bottom edge of the flap and push to open the flap and feel around for where the metal arm goes into the flap. You can paint a mental picture of how it connects to the flap by feeling with your fingers. It is simple to just pull the arm out of the loop on the flap. The flap is spring loaded to stay open and the metal lever or arm just hangs in it's original position. Once you have done it, it only takes 10 seconds to switch back and forth.
Old May 31, 2007 | 03:56 PM
mini555's Avatar
mini555
Supersprint 'street' muffler w/ connecting pipe (no resonator)...can't wait!!
http://www.supersprintna.com/categor...tegory_id/139/
Old May 31, 2007 | 06:01 PM
tc4653's Avatar
tc4653
JCW upgrade kit installed today. JCW intake, new injectors, new JCW control unit and program. Two words, OH MY!
Old Jun 2, 2007 | 05:50 AM
Maskita's Avatar
Maskita
Thanks Cactusflier, it worked like a charm.
Teh
Aug 22, 2022 04:37 AM
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
