Interior/Exterior New STRI gauges
Old Apr 26, 2007 | 01:40 PM
  #151
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
A package deal would be great...did you (StoopidGirl) get my pm?
Send me a pm when you get the time and know what is up in response to my questions. Thanks. Chris.
Old May 3, 2007 | 12:35 PM
  #152
loveminis's Avatar
loveminis
well, I'm really not a complainer so when I say that the reading of these gauges is hard in bright light as well as semi cloudy days, it truly is hard for me. I still believe the simple way to go is to just make the lens clear and have the background white like the OEM; what could be easier than that?
Old May 3, 2007 | 01:53 PM
  #153
batrugger's Avatar
batrugger
Actually they do come like that:
Clear Lens an Amber backlight. If you want then to look OEM, there are lot's of other companies that already offer guage packages. These were offered as an alternative to the OEM look.
http://www.striracing.com/pro_x.htm
Old May 3, 2007 | 03:43 PM
  #154
kapps's Avatar
kapps
That's why I passed on these gauges and went with Stewart Warner. I wanted to keep the stock look and backlighting style.
Old May 7, 2007 | 10:11 AM
  #155
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Ok, so I got Gauges I while back everything works good except they dim in reverse of my Tach and Speedo. I disconnected them from the red/grey runner wire by the fuses, tested them individually back on the grey/red wire and they still dimmed backwards.
Any Idea on what I may have done wrong?
I couldn't have done that much wrong. Everything is working.
All the wires for the 2 gauges are tied together (ground and ground, Ignition and Ignition, Dimmer and Dimmer)
Ignition wire is connected to fuse 32 (cig lighter) by an add a fuse.
Ground is connected to a bolt on the fire wall left of the clutch pedal.
Dimmer is connected to the Grey/red runner in the wire bundle next to the fuse box.
Old May 7, 2007 | 07:19 PM
  #156
golden_child
can somebody tell me how/where they have their Ignition (+12v), ground and dimmer hooked up?
I'm trying to trouble shoot my dimming backward issue. I can't seem to figure it out. I thought if I ask people with STRI guages it'll be easier to figure out.
TIA
mine is:
Old May 9, 2007 | 08:28 AM
  #157
Wagnbat's Avatar
Wagnbat
I'm taking mine to WS Motorcars in Annapolis and going to have them do it.
I took it there yesterday and got a quote, and Samson pointed out the best place may be the cig lighter. I said WTF, the cig lighter? And he said yeah, it's got a light ring that dims with the rest of the dash! Power, illumination, and ground can all be tapped at that point. OMG SMRT!
So yeah, they're going to install my new megan springs, bumpstops, JCW steering wheel, and complete the eletrical wiring for my STRI Boost Gauge.
Old May 10, 2007 | 06:37 AM
  #158
golden_child
When are you going. Sorry I missed you last night for the Va coffee meeting.
Old May 10, 2007 | 09:55 AM
  #159
Scavenger's Avatar
Scavenger
I've got the aux gauges that are supposed to go on the steering column (boost & volts), the harness actually piggybacks off of the toggle panel.
Old May 10, 2007 | 01:51 PM
  #160
Wagnbat's Avatar
Wagnbat
I'm scheduled to fly May 17th.
The Batmini is at WS Motorcars in Annapolis getting the gauges installed right now. Yaaaaayyyy!
Old May 10, 2007 | 05:54 PM
  #161
batrugger's Avatar
batrugger
Cigarette Lighter is where I tapped for dimming illumination. There were too many similar red and grey wires next to the fuse box
Old May 15, 2007 | 04:04 PM
  #162
GBMINI's Avatar
GBMINI
Has anyone fitted these in a GP? I'd love to see how they look ...
Old May 16, 2007 | 06:08 AM
  #163
StoopidGirl's Avatar
StoopidGirl
oooh good idea. I'm checking which gauges are available now, I think they all should be so maybe I can put together a GP friendly package The smoked ones would go nicely but I'll look
Old May 16, 2007 | 06:10 AM
  #164
Loony2N's Avatar
Loony2N
Somewhat off-topic, but does anyone know if there is a water temp gauge available for the R56 yet??
Old May 16, 2007 | 06:28 AM
  #165
golden_child
Any water/coolant temp gauge would work. You would just have to find a spot to tap for the temps. As far as specific for R56, I don't know. But almost any should work.
Old May 16, 2007 | 07:07 AM
  #166
Loony2N's Avatar
Loony2N
I guess I should have worded that more specifically. I meant one that has a pod that will hold it logically in the R56.
Old May 16, 2007 | 07:10 AM
  #167
golden_child
Oh, got it.
Old Feb 26, 2008 | 08:03 AM
  #168
golden_child
Yesterday as I was turning the car on and letting the gauge do it’s start-up sweep it do what it normally does. The light came on, started to sweep then it stopped it’s sweep a tick under 180 then went back down to 0 instead of going all the way to 300, blinking then back to 0.
Then as oil temp rises it gets stuck at a tick under 180 for a while before it’ll go over it. I can actually see the needle trying to get over that temp. The needle bounces up and down just slightly like it’s pushing but can’t get over it then it finally breaks free and gives me a reading over 180.
Is there warranty for this? I feel like I can’t trust the gauge reading.
Has this happened to anybody? I emailed STRI also.
Old Feb 26, 2008 | 08:37 AM
  #169
StoopidGirl
GC-let me know if you don't hear back from STRI. I would think they would help you out. I know it's still considered a newer line so maybe it's just a kink they've worked out. Good luck
Old Feb 26, 2008 | 08:45 AM
  #170
golden_child
Thanks. I sent them a a quick time vid of the start also.
the contact was autotechinteriors, right?
Old Feb 26, 2008 | 10:44 PM
  #171
danielo's Avatar
danielo
What are the differences between the X-Line and the DSD line?
It doesn't say in their website.
Also, are the Stri gauges totally silent during and not during operation?
Old Feb 27, 2008 | 06:19 AM
  #172
golden_child
Not sure about the differences in the line but I can answer your second question.
Yes the X-line is totally quiet during and not during operation.
Old Feb 27, 2008 | 07:16 PM
  #173
StoopidGirl
Not sure about those questions either. I quit carrying them due to not knowing anything about gauges! LOL...just not my thing.
GC-yes that was the correct contact
Old Feb 27, 2008 | 08:02 PM
  #174
danielo's Avatar
danielo
er... Ok.
Been searching around but i still can't find the answers.
I sent an e-mail to stri, haven't received any replies yet.
Old Feb 28, 2008 | 06:11 AM
  #175
golden_child
I haven't heard from them either.
I just resent them my emails. I'm just waiting to hear from them. I should fall within warranty...I think.
auto-tech's warranty policy
Auto-Tech Interiors Inc. prides itself on providing the highest quality products available to our customers. We have confidence in our materials and workmanship and provide a 1-Year Limited Quality Assurance Warranty with each product, which covers all manufacturing defects.
In the event of a valid claim due to defective material or workmanship, Auto-Tech Interiors, Inc. will provide a replacement product as quickly as possible.
Proof of purchase (receipt) from an authorized dealer and the original item must be returned to your regional distributor to be considered for a warranty replacement. All products must be correctly installed to be considered and will be inspected upon return to verify damages. This warranty does not cover damages caused by improper installation, abuse, or mishandling. Customers will be responsible for shipping and handling charges for the replacement product.
In no event shall Auto-Tech Interiors, Inc. be liable for indirect, consequential, or incidental damages of any kind. Any claim must be asserted within one year of the purchase date.
All implied warranties are limited in duration to the applicable warranty period. Auto-Tech Interiors, Inc.'s obligation under this warranty is strictly and exclusively limited to the replacement of defective parts. And Auto-Tech Interiors, Inc. does not assume or authorize anyone to assume for them any other obligation.
