Interior/Exterior Aero Grill Install?
Old Jun 16, 2006 | 01:12 PM
AstroBlackBeast's Avatar
AstroBlackBeast
Aero Grill Install?
I just got the Aero Grill for my 2006 Cooper S and people say it's a pain in the butt to install. Are there any how-to's on this install? Any tips? Any help would be great! Thanks alot guys
Old Jun 16, 2006 | 01:19 PM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
here you go. It's of off motoringfile.com
http://www.motoringfile.com/diy/
the 11th one down.
Take your time. measure, remeasure.
oh ya take your time.
Old Jun 16, 2006 | 07:37 PM
DreamWeaver's Avatar
DreamWeaver
I found it easier to spray paint the bottom grill rather than replace it. The look is about the same and you can you won't have to work over your bumper.
Good luck!
Old Jun 16, 2006 | 09:30 PM
Nuff's Avatar
Nuff
It's not nearly as bad as all that. Just take your time and don't burn yourself with the Dremel!!
The top part should be no problem.
The lower grill is the one you have to trim with the dremel to get it to fit the stock MCS bumper. I removed the front bumper, but some folks here were able to do it without removing the bumper. If you do a search, you can find the instructions.
I followed the Motoringfile instructions pretty closely (don't worry, you will remove A LOT of material) and left the tabs on the grill. Then I used the dremel to cut slots in the bumper (that was the most nerve racking part) so the tabs could be inserted. They snapped in perfectly.
Here's what the instructions said:
With the 1/8”drill bit in the dremel tool, you can drill one hole in each of your center point markers, then a hole on each of side of it at about 3/8” and then use the side of the bit to plow through the material between the holes. At high speed, it essentially melts the plastic out, making a very tidy slot
Good luck. Take your time. It's worth it!!!
Old Jun 17, 2006 | 03:47 PM
omascow's Avatar
omascow
I just did mine without removing the bumper. A nice sturdy putty knife to pry the old one off and just had to sit on the garage floor to get eyelevel in order to dremel the slots right. Wasn't that hard, just time consuming.
Oh and those plastic bits burn like fire!
Old Jun 17, 2006 | 04:06 PM
qweewq12's Avatar
qweewq12
Ditto! Not a brainbuster..just take your time..
Well worth it.. very sharp...
Old Jun 20, 2006 | 02:07 PM
acitydweller's Avatar
acitydweller
I love the aero grills
Old Jun 20, 2006 | 02:26 PM
TWISTER's Avatar
TWISTER
I just did this MOD for a fellow club member. I had done mine last year and it does take time but well worth the look. It took us about 2 hours to complete it
Old Jun 20, 2006 | 05:40 PM
omascow's Avatar
omascow
I'm proud of my work so I think I'll show everyone.
Old Jun 21, 2006 | 01:16 PM
AstroBlackBeast
Thanks alot guys, I just bought a new Dremel so I'm pumped to break it in. Now all I need to do is find the time to do it. I think half a sunny sunday and a case of Honey Brown should do it. I'll post pics when I'm done
W0TM8
Dec 19, 2019 07:50 AM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
