Interior/Exterior Using stealth bulbs in clear tail lights?
Old May 1, 2006 | 01:41 PM
BoCRon's Avatar
BoCRon
Hi all, I'm also going to post this in electrical since I'm not sure where this question really goes.
I just changed out the tail lights on my 06 MCS to the clear altezza type lights. I used the LED light recommended for the brake portion of the light (the very bottom of the 3 bulbs) and they are great. I'm thinking that it would be a good idea safety-wise to use a stealth bulb for the center (turn signal) bulb. With the new set up, the signal bulb now flashes a white light and I think the amber is a better light for a signal light? All three bulbs are the exact same size and the bulb I bought at AutoZone for the bottom was #1157. I'm thinking that I can order a stealth bulb of that same model number and it should be fine??
Any input or reasons why I should or shouldn't do this?
I'm going to post pics this evening.
Annette
Old May 1, 2006 | 02:23 PM
eVal's Avatar
eVal
I'm all for amber turn signals, I think they are more distinct intention wise (you don't confuse them with anything else and they get your attention that someone is indicating a turn/lane change). I have used Silvervisions in several cars with clear lamp housings, including the Mini, and love them: http://supremepowerparts.com/product..._Blinker_Bulbs
Can't see why those or bulbs like them would not work for you too.
Hope that helps
Old May 1, 2006 | 02:32 PM
SonicVI's Avatar
SonicVI
You'd probably want an 1156 for the turn signal, 1157 is dual filament which you don't need.
Old May 1, 2006 | 03:14 PM
BoCRon's Avatar
BoCRon
YAY, Thanks y'all for the help. I used eVal's link and switched to the 1156 per SonicVI and saved enough to have them overnighted!
Love ya, mean it
Oh, and here's a pic of the new hindquarters, so to speak.
BEFORE
AFTER
Annette
Old May 2, 2006 | 07:00 AM
anathema's Avatar
anathema
Time to clear out that 3rd brake light!! Nice car!
Old May 2, 2006 | 07:10 AM
sddave's Avatar
sddave
Looks good!
Are these the e-bay altezza lights you mentioned in a post a couple of weeks ago? Did you have any problems with wiring them up?
Old May 2, 2006 | 08:01 AM
BoCRon's Avatar
BoCRon
These are the ones from ebay. I rec'd them in about 3 days, so that was great. Since I have an 06, I did have to get 2 bulb sockets from the MINI dealer. I then bought the LED 1157 bulbs from Autozone to use in the bottom socket for the brake lights. Not a prob at all to get in, very worth the time and $$. About $55 for the lights, $30 for the MINI parts and $18 for the LED lights.
Annette
Old May 2, 2006 | 09:59 AM
The MINITOR's Avatar
The MINITOR
FYI, Polarg makes the "stealth" bulbs as well. I get mine at the local import tuning shop.
Old May 2, 2006 | 11:12 AM
DownSize's Avatar
DownSize
Ill PM you, I have a ? about the LED tail light.
Sexual Chocolate
Mar 31, 2019 08:02 PM
cm.d
Aug 19, 2015 08:51 AM
I_drive_slow
Aug 18, 2015 10:47 AM
messyjesse96
Aug 12, 2015 05:51 AM
