Interior/Exterior Home Made Hood Scoop Grill question
Old Jul 8, 2005 | 07:23 AM
ripley's Avatar
ripley
Read all the threads (I think I found them all) on making a hood scoop grill out of the mesh metal "gutter guard" material. So I trotted off to to Home Depot and bought some. Got home and started playing with. Problem is...I'll be damned if I can figure out a good way to attach the grill to the scoop. Can some of you experienced "pros" shed a little light on this issue???
Thanks a bunch,
ripley.
Old Jul 8, 2005 | 07:33 AM
biggripper's Avatar
biggripper
No attachment needed. You cut the mesh to fit so that it is actually just small enough to fit and then it gets sandwiched between the outer part of the scoop and the inner part. This is how I did mine over a year ago...no problems.
Sean
Old Jul 8, 2005 | 09:01 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
What he said ^^^^
Old Jul 8, 2005 | 10:35 AM
ripley's Avatar
ripley
I must be really slow or I have a different scoop. My scoop is one piece. I don't have an outer part and an inner part. What am I missing here
ripley.
Old Jul 8, 2005 | 11:31 AM
MadHatter's Avatar
MadHatter
The inner side of the frame (read - hood) has a slightly
larger area and the black part (at least on my 05 MCS it is black) just holds it in in front.
Good luck
Old Jul 8, 2005 | 12:42 PM
wmba's Avatar
wmba
Remove the scoop from inside (under the hood).
Once you have it out.. you should see a little lip on the plastic housing where it comes into contact witht the hood. Cut your mesh to fit inside this lip.. and when you re-attach to the car.. it will stay in place.
Hope this helps.
Old Jul 8, 2005 | 12:44 PM
BFG9000's Avatar
BFG9000
The black part under the hood is held on with 2 phillips and 2 10mm nuts. When you remove those and the scoop tray there will still be 2 other nuts holding the separate painted part of the scoop onto the hood.
Old Jul 8, 2005 | 01:34 PM
ripley's Avatar
ripley
Ok...I see. Finally. I was trying to place it in the hood scoop opening only. Geez, somtimes I'm amazed at how stupid I am
Thanks to all for taking the time to set me straight!
ripley.
Old Jul 8, 2005 | 04:57 PM
Tarzan's Avatar
Tarzan
Pics of one disassembled, anyone?
Anyone have a pic of this component disassembled?
boostedhaze
Jan 2, 2018 07:26 PM
marendt428
Feb 25, 2016 07:13 AM
O4mcs
Aug 10, 2015 10:22 PM
jrezzo
Aug 9, 2015 10:32 PM
