Interior/Exterior Lower Aero Grille Install Question
Old Jun 30, 2005 | 05:00 PM
not-so-rednwhitecooper
hey guys,
i just got my aero grilles today, i broke my stock grille taking it off, so i figured it was an excuse to go buy the aero grilles.
top one, no brainer, popped right in and the fit is awesome!
bottom one, little more of a challenge....
i cut around all the tabs down to about 1/8 inch away from the edge of the grille. then i found out all the tabs were off, so i figured i would just two side tape it on so i cut all the tabs off so it will fit nicely.
ok, sit in there great and the fit looks perfect, but i had a problem, the two way tape doesnt touch the back side of the grille, so it wont hold!
i was just wondering i anyone has simply screwed the grill down with about 4-5 screws from the front on the outside. i thought it might give it a racey look to it with some black round domed head allen head screws holding it down.
i think i'm gonna go tomarrow to get the screws for it.
whatcha guys think?
Old Jun 30, 2005 | 05:07 PM
Justanthony's Avatar
Justanthony
i would first try figuring out a way to mount it without putting screws through the front. in my humble opinion, that looks "slapped on".
Old Jun 30, 2005 | 06:29 PM
AldoS's Avatar
AldoS
I wouldn't screw it on. I'd buy another lower grill if that's what it takes.
I had no problem with mine. Good install instructions are only a search away.
Old Jun 30, 2005 | 08:12 PM
well, after looking at my grille again, i noticed a pretty big gap at either end of the grille on the top, so i think i'm just gonna buy another, and be super carefull this time.
i hadnt read that you had to slot the holes for it to fot, and that was my problem. easy fix, i just hope Classic has another one in stock!!!!
Old Jul 1, 2005 | 04:26 AM
62Lincoln's Avatar
62Lincoln
This might help: https://www.northamericanmotoring.co...10&postcount=1
Good luck!
Old Jul 1, 2005 | 12:12 PM
thx man, that did help!
Old Jul 1, 2005 | 01:48 PM
yay got it on!
i need to pull up the corners and remove a bit more material alter on, it isnt exactly flush, but it looks sweet!
Old Jul 1, 2005 | 02:53 PM
62Lincoln's Avatar
62Lincoln
Time for pix!
Old Jul 1, 2005 | 08:23 PM
i got em, just gotta uplaod them, i'll get it later when i upload my new aero tail light pix too!! (clears)
Old Jul 2, 2005 | 09:59 PM
pics!
Old Jul 3, 2005 | 04:17 AM
62Lincoln's Avatar
62Lincoln
Looks very nice. Good job!
Old Jul 3, 2005 | 09:58 AM
ScuderiaMini's Avatar
ScuderiaMini
Looks good
Old Jul 3, 2005 | 10:06 AM
Before and After
Old Jul 3, 2005 | 10:18 AM
minimonkey's Avatar
minimonkey
Epoxy glue! That's what I did and it looks GREAT. Don't screw it on. I left enough of the tabs to touch the bumper cover, and I glued it there and along the bottom... it's solid!
Expoxy glue from your local auto parts store for about $5 will do the trick. Best of luck.
Old Jul 7, 2005 | 08:09 PM
iriedub's Avatar
iriedub
rednwhitecooper, are you interested in selling your old grille?
W0TM8
Dec 19, 2019 07:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
