Interior/Exterior Schroth harness install in a 05 MCS
Old May 17, 2005 | 03:35 PM
Hounddog's Avatar
Hounddog
Anyone installed one. The link I found on here showing pictures didn't exactly make sense on the front bolt location for the strap. I'm assuming it is the one on the side of floorboard right below the sill plate that the stock seat belt strap is attached to. Am I correct? Looks like all the rest of the pictures are correct for installation.
Old May 17, 2005 | 04:14 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
you are correct. one of the latches goes on the bolt near the floor on the outside of the front seat.
Old May 17, 2005 | 05:14 PM
leon's rocket car's Avatar
leon's rocket car
yep, that's where I put mine in a few weeks back. I think I used a 19mm
Old May 17, 2005 | 07:05 PM
LeftyS7's Avatar
LeftyS7
I've just been corresponding with HMS about this very issue and was going to try to fit the harness tonight. The factory belt goes on the bolt first and then the Schroth piece. Then put the bolt back in place.
Old May 18, 2005 | 05:22 AM
leon's rocket car
Yes, that is how I did it. works fine.
Old Aug 2, 2005 | 01:38 PM
lsd05jcw's Avatar
lsd05jcw
2005 install
Wondered about this also, as it is the case on the 2004 model year also. So is that install method officially approved by Scroth??? Also, then is there a longer bolt to use? This is not a place for guessing....
2005 Cooper S
Last edited by lsd05jcw; Aug 2, 2005 at 01:40 PM. Reason: adding one more related question
Old Aug 2, 2005 | 01:55 PM
Hounddog's Avatar
Hounddog
That's exactly how I did mine....
Old Aug 2, 2005 | 02:35 PM
MandaBoo's Avatar
MandaBoo
they do supply a longer bolt for the back seat, but the one next to the front seat already has quite a long bolt. the whole install tok me about 10-15 minutes.
Old Feb 4, 2006 | 11:12 PM
FlynHawaiian's Avatar
FlynHawaiian
So where exactly do I bolt this to? Do I bolt it to the front seat part rear plate or bolt it to where the torx bolt is that attaches the seatbelt to the side of the car? Need help :(
Do I need bolts different than the factory ones or what?
Old Feb 5, 2006 | 08:14 AM
FlynHawaiian
NEVER MIND the install was super easy
W0TM8
Dec 19, 2019 07:50 AM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Super Coop
Aug 17, 2015 05:09 PM
