Interior/Exterior Black Exhaust Tips?
Old Sep 1, 2013 | 10:07 PM
OC40's Avatar
OC40
Black Exhaust Tips?
We just leased Mini S Hardtop for my wife (see thread in 1st Gear). I added black chrome tips to my 335 MSport and my wife loves the look. I searched MINI's website and this forum and I could not find OEM black stock tips. Does anyone know if we can purchase these? I a post on here that added black ceramic to his/her tips but the company is in Detroit.
Thanks in advance!
Old Sep 1, 2013 | 10:22 PM
c w's Avatar
c w
Check my one ball and tips mod in the R50/R53 driveline section
I had some big tips made and are painted with black heat proof ceramic paint (note its not the black chrome look)
Old Sep 1, 2013 | 10:44 PM
OC40's Avatar
OC40
Thanks CW! Looks nice but I am lazy. I just want to buy a set or have someone coat ours locally.
Old Sep 4, 2013 | 12:26 AM
user 7398330's Avatar
user 7398330
Personally I took the tips off did about 4 coats of black plastidip and it looks great. Hold up no problem with exhaust heat as well as the 120 degree Arizona sun.
Old Sep 4, 2013 | 07:57 AM
bateater's Avatar
bateater
Yep, you should be able to plastidip them and it should hold up.
Old Sep 4, 2013 | 06:19 PM
OC40's Avatar
OC40
I'll check into plasti-dipping. Thanks for the info.
Old Sep 4, 2013 | 07:19 PM
user 7398330
Its really easy. Scrub them down real well after taking them off and then coat the outside etc for a couple coats and or good to go!
Old Sep 5, 2013 | 07:10 AM
yetti96's Avatar
yetti96
I'm glad I'm not the only one who has PDed their tips. It looks so much "cleaner"
Old Sep 5, 2013 | 08:15 AM
OC40's Avatar
OC40
Thanks everyone for the info on PD. We will definitely look into it. Can one of you post a pic please?
Old Sep 5, 2013 | 08:32 AM
kkcshipp's Avatar
kkcshipp
Did you just pour the plasti-dip over them? Or is there a spray version my Lowe's does not carry?
Old Sep 5, 2013 | 08:37 AM
RobMuntean's Avatar
RobMuntean
Spray about four to five coats.
Old Sep 5, 2013 | 08:39 AM
kkcshipp's Avatar
kkcshipp
Got it, thanks! One visit to Bing and I found the spray. I'll execute that this weekend in between football games. I'm tired of trying to keep them clean.
Old Sep 5, 2013 | 10:24 AM
InjectedGT's Avatar
InjectedGT
People actually use Bing?
Old Sep 6, 2013 | 05:42 PM
Melangell's Avatar
Melangell
$30 to have them powder coated all of the way forward to the muffler.
Old Dec 2, 2013 | 12:57 PM
Gamble_Rumble's Avatar
Gamble_Rumble
"people use bing?" hahahaha
Old Dec 2, 2013 | 01:02 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Black Chrome... I saw a set recently on a new 911.
I like the look, hard to find though.
Old Dec 2, 2013 | 01:24 PM
rckrzy1's Avatar
rckrzy1
mine get black shortly after washing all on their own.
Old Dec 2, 2013 | 01:26 PM
imaking's Avatar
imaking
Black chrome can be done with Plastidip
Old Dec 2, 2013 | 02:19 PM
There is ones form the BMW side. They look to be the slide on type. People on the BMW side have had them tack welded on.
http://www.ecstuning.com/Search/SiteSearch/ES40649__ES2537204
I don't have the internal Id or inner dimensions. Some of the BMW boards have info on the cars.
18307559999 is from the E82 135
18307610639 is from the F30 2.8 L and F32 2.8 L
Gives you some ideas.
Old Dec 3, 2013 | 03:59 PM
OC40's Avatar
OC40
There is ones form the BMW side. They look to be the slide on type. People on the BMW side have had them tack welded on. http://www.ecstuning.com/Search/SiteSearch/ES40649__ES2537204/ I don't have the internal Id or inner dimensions. Some of the BMW boards have info on the cars. 18307559999 is from the E82 135 18307610639 is from the F30 2.8 L and F32 2.8 L Gives you some ideas.
I have an F30 with black chrome tips, so I am familiar. Trying to find OEM black tips for my wife's mini s without having to powder coat and/or plastidip.
Old Dec 3, 2013 | 04:18 PM
signcarver's Avatar
signcarver
Those look terrific!
Would powder coating be the most durable way to go? is it a matte finish?
Years ago i had a Boxster and i could use a fine steel wool and silver polish to really shine the exhause tips. I had some success with my '09 JCW but the coating started to wear off.
I would either like to have a durable stainless finish or the black like yours.
Thanks,
Steve
Old Dec 3, 2013 | 05:01 PM
calforhelp's Avatar
calforhelp
If you want a gloss black finish use Rust-Oleum Engine Enamel. The exhaust tips have a little screw on the bottom. Loosen that and the tips will pop right off. I just painted them with 4-5 coats and they have a great gloss black finish that matches my car great. I think they actually look quite a bit better than matte black even on my car.
Old Dec 4, 2013 | 05:05 AM
Was trying to dig around to find something else. There is no factory black chrome tips from MINI. I was trying to come up with a solution using the BMW parts. Hope that helps. Good luck on the find.
Old Dec 4, 2013 | 06:14 AM
OC40's Avatar
OC40
I appreciate it. Hopefully, mini comes out with something. If not, we will keep it chrome.
Old Dec 4, 2013 | 06:16 AM
RicWRX's Avatar
RicWRX
Don't mean to thread jack, but tail lights do you have?
sevin
May 2, 2026 06:11 AM
adrchn
Aug 13, 2019 02:11 AM
ASRman
Aug 13, 2015 09:33 AM
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
