Interior/Exterior Gauge mounting option
Old Feb 29, 2004 | 07:53 PM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
There are many different mounting pods designed specifically for MINI, but most of them are quite costly. I decided to experiment with a less expensive alternative, Auto Meter mounting pods at $12 each. They worked out perfectly for MINIs. The pods allow tilting and angling of the gauges for optimum viewing.
:smile:
Notice that the illumination of the aux gauges matches with MINI's orange red. :smile:
Old Feb 29, 2004 | 08:03 PM
dcsmd007's Avatar
dcsmd007
Here're some other mounting options. :smile:
E-pods from
MINI Madness and Mini Mania
Alta mounting pods from Outmotoring
Old Mar 1, 2004 | 10:50 AM
Moorlockx's Avatar
Moorlockx
Your new set-up looks great...especially when you compare pricing with the other sets. :smile:
Old Mar 1, 2004 | 11:16 AM
sanddan's Avatar
sanddan
Do you have a picture showing the pod installed and how it was done? THanks
Old Mar 1, 2004 | 12:17 PM
nparker's Avatar
nparker
I used the Autometer mounting cups and came up with this home made mount:
I'm working on the next generation of the mount. Hope to have it done in hte next week or so.
Old Mar 1, 2004 | 12:23 PM
sanddan's Avatar
sanddan
Very nice job, I am inspired. I am going to have to add gauges soon.
Old Mar 1, 2004 | 01:13 PM
MSFITOY's Avatar
MSFITOY
Very nice job everyone...would you guys mind posting the links to where I can find these guages?
Are these electrical or mechanical guages?
Price?
Thanks very much.
Sid
_________________
Old Mar 1, 2004 | 04:05 PM
sanddan's Avatar
sanddan
Either Summit Racing or Jegs have Autometer gauges. Check out their web sites.
Old Mar 1, 2004 | 05:33 PM
dcsmd007's Avatar
dcsmd007
I bought the gauges from Summit Racing. They carry a wide range of Auto Meter gauges. :smile:
Old Mar 2, 2004 | 05:13 AM
MSFITOY's Avatar
MSFITOY
Please, are these electric or mechanical? I think I've heard that most people are using 2 1/16 mechanical boost guages and electric oil. Is this correct?
Thanks.
Old Mar 2, 2004 | 08:33 AM
KevinR's Avatar
KevinR
:smile:
Old Mar 2, 2004 | 12:11 PM
sanddan's Avatar
sanddan
Are there any how-to's on mounting the gauge senders?Does the oil pressure mount on the filter cover? Where do you mount the boost sensor? Thanks for the help.
Old Mar 2, 2004 | 06:35 PM
nparker's Avatar
nparker
>>:smile:
I've considered making and selling these. I need to work out some more details for the next generation. It will be very similar to this one. I haven't had the time lately to devote to it, but I should in the next few weeks. I also need to get a new powder coat gun so I can put a durable finish on them. I'll keep everyone updated if you're interested.
Thanks,
Nyle
Old Mar 5, 2004 | 07:23 AM
sanddan's Avatar
sanddan
Bump
Old Mar 5, 2004 | 07:48 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
davecsumini,
That setup looks great! I'm sure you'll sell lots of them if you decide to make them and the price is much lower than what's already out there.
Old Mar 5, 2004 | 07:56 AM
MSFITOY's Avatar
MSFITOY
I would be very interested in a version for Nav system too
Old Mar 5, 2004 | 08:02 AM
grendalsiii's Avatar
grendalsiii
Ditto on the nav. I can send dementia..er dimensions or might suggest a single sided yoke that can be mounted left or right.
Nice job on the fabrication, very elegant install.
Old Mar 6, 2004 | 02:07 PM
sanddan's Avatar
sanddan
What color and location wire do you use to hook up the gauge lights? Thanks for the help.
Old Mar 6, 2004 | 05:55 PM
dcsmd007's Avatar
dcsmd007
The grey/pink wire from wire harness that goes to the tach is the closest place to get power for gauge light. This will allow the light to dim like the fatory dash lights. :smile:
Old Mar 7, 2004 | 09:29 AM
sanddan's Avatar
sanddan
davecsumini,
Which wire did you use for the keyed power source? Last night I got the intercooler out of the way and installed tee on the nylon line going to the fuel presure reg. I hope to have the boost gage finished today. Where did you hook up hte oil pressure sender? I can see how to fit up to the filter housing but can't find the factory oil pressure sender location.
Wohnson89
Jun 10, 2020 04:53 AM
Aug 19, 2015 12:51 PM
Phantogram
Aug 12, 2015 12:11 PM
pewx3
Aug 7, 2015 03:34 PM
