Interior/Exterior LED Fog Light DRL's from OutMotoring
Old Mar 10, 2012 | 01:29 PM
  #76
XRAMX's Avatar
XRAMX
Originally Posted by teamrubixcube
How did you guys run your wire up to the battery compartment? I haven't installed mine yet but after scoping it out today I'm not sure how I'm going to get the wire into the compartment.
I ran the wires on the right of the headlight (underneath) then near the battery there is a ruuber soft moulding for the hood and where it ends on the left there is space to run the wire in between. I hope that makes sense.
Old Mar 11, 2012 | 06:56 PM
  #77
Gillham's Avatar
Gillham
Originally Posted by Flamewinger
Just because you get away with it doesn't make it legal. Many run red lights and get away with it. The laws are not enforced as they should be and people are doing whatever they want. Yes, you are able to drive with any lights but that doesn't make it OK. A fellow worker got a ticket for driving with parking lights so it's possible to get noticed. Expensive too. With the depression and governments looking for extra funding, it's even more possible.
Ok, let me rephrase what I said earlier, it's not illegal in Massachusetts.
http://www.malegislature.gov/Laws/Ge...ter90/Section7
Also I'm having a heck of time finding acceptable or proper use of lights, more specifically use of fog lamps or auxiliary lights for California, where it limits the use only during inclement weather. Mind linking me? All I can find are code restrictions, colors, placement, number of lights etc.
http://www.dmv.ca.gov/pubs/vctop/vc/vctoc.htm
Old Mar 11, 2012 | 07:18 PM
  #78
teamrubixcube's Avatar
teamrubixcube
I checked out that spot today and it looks like you're right! I'll likely try going the same route. Maybe tackling this job after work Tuesday. Should get home around 3:15....gets dark around 6:45. If it takes longer than that...well, then I'm a very slow worker
Old Mar 12, 2012 | 05:27 PM
  #79
teamrubixcube
Alright, so I just finished doing the installation. Anybody else having a problem with brightness? They are awesome and both very bright when they are the only light on. However, with the xenons turned on the passenger side is noticeably more dim....to be honest, I wish they were both that dim. As soon as I turn the headlights off, back to both being bright.
Also, the fitment for the fog lights themselves aren't matching up. I may need to grind down the metal part of the bulb socket so that I can get it attached correctly. Anyone else have a fitment issue with the center fog light?
They do look cool though, and I'm anxious to see them in the daylight tomorrow! They will definitely be able to replace leaving the headlights on for DRL. Very, very bright
Old Mar 13, 2012 | 05:13 AM
  #80
tominizer's Avatar
tominizer
Flickering, install alignment, wiring, brightness. A few little issues to sort out.
Old Mar 13, 2012 | 05:47 AM
  #81
teamrubixcube
You and me both...
EDIT: Found that one of my connections got loose so that my left side wouldn't dim. Connected it up and now they both dim perfectly for when the xenons are on Still a bit of flickering though...but not often. I can live with that.
Old Mar 13, 2012 | 06:48 PM
  #82
wineguy's Avatar
wineguy
You and me both...
Mine keep flickering and they bug me, got to find a solution
Old Mar 22, 2012 | 06:50 PM
  #83
davidtobin's Avatar
davidtobin
if the leds are blasting bright and flicker when first turned on you have reversed the polarity controlling in the plug controlling the leds.
Old Mar 22, 2012 | 06:55 PM
  #84
davidtobin's Avatar
davidtobin
just finished led install
I just finished installing the led lights from outmotoring. just to clear up some f the chatter in this thread about when they are on or not: the leds replaced your parking light so they are on whenever your parking lights would be on. if you have not programmed your key for DRLs then the leds will be on when you turn on your parking lights OR when you turn on your headlights OR when you are programmed for DRL which normally turns on both headlight and parking light but with the leds installed only the led/parking light will be on and it will be brighter than if you have headlights on or parking light only on. The fog light functions as normal thru toggle on dash.
Last edited by davidtobin; Apr 2, 2012 at 11:39 AM. Reason: statement needed correction
Old Mar 23, 2012 | 03:51 AM
  #85
teamrubixcube
I'm probably very wrong, but I thought lights were bidirectional. Mine are very bright at first but as soon as I turn on my DRL's from the light stalk (first click over) they dim down and never flicker. I keep them at this level at all times.
Old Mar 23, 2012 | 05:33 PM
  #86
unibus_driver's Avatar
unibus_driver
LED == Light Emitting Diode.
Diodes are polarity sensitive.
Old Mar 23, 2012 | 06:56 PM
  #87
rayzmini's Avatar
rayzmini
will these fit on a 2012 mcs?????
Old Mar 24, 2012 | 04:47 AM
  #88
teamrubixcube
How do I reverse my polarity back to normal? Would switching the lines to the battery do the trick?
Old Mar 25, 2012 | 08:08 AM
  #89
davidtobin's Avatar
davidtobin
[QUOTE=teamrubixcube;3477993]How do I reverse my polarity back to normal? Would switching the lines to the battery do the trick?[/QUOTE
No. the polarity is reversed at the plug that connects the parking light plug to the male plug in the led unit.
Old Mar 25, 2012 | 11:34 AM
  #90
wineguy's Avatar
wineguy
[QUOTE=davidtobin;3478549]
That's what fixed mine, they should be on (bright) when your car is running and dim down when you turn on your parking lights or headlights.
Old Mar 25, 2012 | 12:33 PM
  #91
davidtobin's Avatar
davidtobin
[QUOTE=wineguy;3478640]
Old Mar 25, 2012 | 12:34 PM
  #92
davidtobin's Avatar
davidtobin
After doing my install and reviewing this thread and two sets of instructions from the manufacturer I have the following to contribute. When I first did my install ONE of my lights was super bright and flickered when first turned on. I revered the polarity on the plug from the car to the led (it sits in the hole in the unit and looks like the connector of a bulb) and NOW both lights are bright when in drl mode and dimmer when headlights on or can be turned on from stalk to parking light setting.
Old Apr 13, 2012 | 11:44 AM
  #93
mentalbob's Avatar
mentalbob
When I installed them, I noticed that the connectors that emulate the bulb ends have '+' and '-' painted on them. I just made sure that the brown wire side of the city light socket was connected to the '-' side of the connector and all went well.
Old Apr 13, 2012 | 02:48 PM
  #94
teamrubixcube
Mine dim down nicely and there's no flickering at all when I have the stalk in the first or second position (DRL position or xenons on...NOT the default everything off position). However, initially when I start the car there is a fair amount of flickering and they don't stay on consistently until I turn the stalk. Is that normal or still the polarity?
Old Apr 15, 2012 | 10:45 AM
  #95
Germarican's Avatar
Germarican
They all look amazing. Is there any fault posted in your vehicles or are they can-bus?
Old Apr 25, 2012 | 01:36 PM
  #96
davidtobin's Avatar
davidtobin
"New" problem with the LED DRLs from Outmotoring
When in DRL mode (programming) switch off/on when come to a stop MOST of the time. When stopped switch off/on whenever I turn steering wheel sharp left or right. Must have something to do with power surge at battery when applying brakes (especially with 3rd brake light pulsar) or electric steering power draw. Aaron at Outmotoring is looking into it. Otherwise work great and dim when turning on headlights or parking lights. Anyone else noticed this? Best to observe when you can see reflection in the vehicle ahead of you.
Old Apr 25, 2012 | 04:26 PM
  #97
MMM's Avatar
MMM
Must you have the fog light option installed for these to work?
Old Apr 25, 2012 | 04:41 PM
  #98
teamrubixcube
This is EXACTLY what I've experienced too. As soon as I turn the stalk to the second position or put my headlights on there is no flickering at all. They are plenty bright even on the 'dim' setting for during the day use. I'm very happy with my purchase.
Old Apr 25, 2012 | 07:14 PM
  #99
wineguy's Avatar
wineguy
This is the same that was happening to me, they would flicker whenever I came to a stop and thought the same thing about the power surge. I found a workaround that works perfect for me. I disconnected the positive connection and now the lights don't come on in the Off/DRL position but come on (in dim mode) with my parking and headlights. No more flickering and are only on when i want then on
Old Apr 26, 2012 | 09:21 AM
  #100
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
Can those who have experienced issues with flickering while stopping or turning, etc list their year and if they have the Xenon lights or standard, etc?
