Interior/Exterior new tires and pressure sensor...???
Old Aug 29, 2010 | 02:26 PM
ngweibing's Avatar
ngweibing
hey all, i did search on forum but it came up with other stuff thta did not help me..i've 2005 mcs conv and just change my stock ruin flats to 17" black rims n tires.
does all car come wit tire pressure sensor? if i do, do i have ot ask mechanic to wired it or will it automatically detect the new rims/tires? if not, does it mean i have to periodically check my tires pressure with a pressure gauge?
sorry for asking but need to knwo it..
thxs alot..
Old Aug 29, 2010 | 02:54 PM
HRM's Avatar
HRM
Gen 1 uses the ABS sensor set up to check roll distance for the tire warning light. Gen 2 needs sensors installed on the rims, so you are good to go. You may want to hold the reset button so the car detects the new pressures, but, it might just do it on its own.
Old Aug 29, 2010 | 02:57 PM
kazlot's Avatar
kazlot
does all car come wit tire pressure sensor? does it mean i have to periodically check my tires pressure with a pressure gauge?
thxs alot..
No, your car has the FTM which uses the abs system.
Yes, you will have to use a tire gauge.
Hope this helps...
Last edited by kazlot; Aug 29, 2010 at 03:02 PM. Reason: Sorry for the redundant post...
Old Aug 29, 2010 | 03:54 PM
dutch2081's Avatar
dutch2081
sensors are built in the hub somewhere...i just changed the wheels on my 05 mcs and its fine ....i was wondering the same thing because i know my nissan are in the rim itself
Old Aug 29, 2010 | 04:47 PM
ngweibing's Avatar
ngweibing
hhmm.. i iwll look inot the things ebveyrone saoid.. thxs os muhc
Old Aug 29, 2010 | 05:20 PM
dutch2081's Avatar
dutch2081
on porlbem
Old Aug 29, 2010 | 07:43 PM
Act_04's Avatar
Act_04
Originally Posted by dutch2081
on porlbem
Old Aug 31, 2010 | 03:09 AM
ngweibing's Avatar
ngweibing
did u figure it out?
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
JamJam43087
Aug 16, 2015 02:02 PM
nomar116
Aug 9, 2015 09:42 AM
