Interior/Exterior Which is the airbag sensor under seat?
I 'borrowed' this photo from another thread.. can someone tell me which connector is the Airbag sensor? My dash light wont go off and the dealer wont 'diagnose' it without me buying a new seat (yes. you read that correctly)
The heavy metal band from Canada?
The problem is:
My dash airbag light went on (not the overhead light for pass weight). Also, my seat heater wouldnt turn off. And coincedentally, my DICE control unit stopped working as well. This all happened around the same time
Took to dealer.. he couldnt diagnose it. But for some reason.. the heater seat thing fixed itself. (while at dealer). Airbag light is still on, which is the bigger issue cause im due for inspection.
so.. what do you think?
The problem is:
Passenger Airbag Problem
My 2007 Mini Cooper S R52 passenger airbag light both the dash and the overhead lights are on. Any suggestions as to what to do without involving the dealer?
Recall Finish in 2010
Yep, the recall was done. Can I disconnect the Yellow plug(under the passenger seat)to turn off the warning lights until I can fix the Problem?
Bryan
No codes
No codes just the dash and overhead lights are on. Is there a way to reset those, ie disconnect the battery?
if the lights are on, you have codes stored in there....you cannot get rid of them by disconnecting the battery......you must fix the issue, and then either find someone with a proper scanner to erase the codes, or go to the dealer.....
another option is to remove the bulbs, but if you get into an accident, insurance company may frown upon that and not honor the insurance policy.....but you didn't hear removing the bulbs from me
Bryan
Bryan
Bryan
Bryan
For reference, by law all airbag wiring is yellow and all high voltage wiring (hybrid or electric car) is orange. Yellow sheathed and connected wires can be a PITA, Orange can be deadly to screw with.
trw92a
Aug 26, 2015 01:47 PM
DWooderson
Aug 10, 2015 09:12 AM
