Interior/Exterior Next blackout step
Old Oct 18, 2009 | 06:00 PM
willsblackmini08's Avatar
willsblackmini08
Next blackout step
The Interior.
i want to pull the door off of the secret compartment, the same spot right at the top of the steering column, and also the saem pattern on the doors(I'm not sure what it is called) Pretty much all that silver checked stuff on my interior and paint it black. Does anyone have a write up on how to pull off all of these parts. I'm not so much worried about the secret compartment panel that's the easy one. it's the doors and steering colomn that I'm having trouble with.
Old Oct 18, 2009 | 06:57 PM
Porthos's Avatar
Porthos
Trade someone don't paint
Old Oct 18, 2009 | 07:02 PM
selkie's Avatar
selkie
I had to remove the gauge cluster piece this weekend to install my new driving lamps.
It simply snaps into place, you can just pull it off. I believe there are three interfaces, one on each side, one in the middle. You do have to pull pretty hard.
Not sure about the door pieces.
Old Oct 18, 2009 | 07:38 PM
Robin Casady's Avatar
Robin Casady
Some find it easier to unscrew the tach to get better access. Then just pull it off.
When your paint job goes horribly wrong, you can buy replacement parts through AutoXCooper, Pelican Parts, or ECS Tuning. Get the part numbers from RealOEM.com.
Old Oct 20, 2009 | 12:46 AM
Sketch's Avatar
Sketch
Wrap your trims in vinyl, dont paint them.
Old Oct 20, 2009 | 07:14 AM
thevelourfog's Avatar
thevelourfog
Aren't those textured? Why not just get some used Piano Black trim pieces?
Old Oct 20, 2009 | 07:23 AM
drewstermalloy's Avatar
drewstermalloy
+1. I was thinking of painting them for a minute too, but vinyl would be much more practical. Probably last longer too.
Old Oct 24, 2009 | 12:34 PM
willsblackmini08
Maybe I'll wrap them. First thing is getting them off. The door is going to be tricky. The next nice day here in CT I'll figure it out. Come on nice weather on Wednesday.
Old Oct 24, 2009 | 12:42 PM
iwashmycar's Avatar
iwashmycar
http://www.drycarbonwrap.com/
this can look pretty amazing^^^^
Ive tossed around the idea of getting something different than my piano black, but so far the only thing id probably replace it with is Carbon fiber...
Old Oct 27, 2009 | 12:50 PM
Chemdean's Avatar
Chemdean
I would like to wrap my door trim as well. If anyone finds an easy way to do it, please share. Removing the trim from the door requires a set of new fasteners, I think.
Old Oct 28, 2009 | 01:40 PM
dtsoccer6's Avatar
dtsoccer6
Good luck Will.
There is a fellow CT owner upstate that painted his and it came out awesome, even til this day. His name is Kevin and he changed his from stock to black and yellow to match the mellow yellow and black roof. I'll try and get his username so you can give him a PM for help.
Getting the replacement pieces would be ideal however, and probably easier. Ask Lyle as well, maybe he can wrap them for you for less.
Good luck!
vetsvette
Oct 20, 2015 07:42 AM
schr5530
Oct 5, 2015 08:28 AM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
