Interior/Exterior Stripes!!! How do you put them on ??
Old Oct 29, 2003 | 09:49 PM
Kuneman's Avatar
Kuneman
Are the stripes painted on or how else are they applied on?
Do you put them on yourself or can you get them professionally done, because i dont want to stuff the stripes and my car up?
Old Oct 29, 2003 | 10:07 PM
minicoop78's Avatar
minicoop78
the stripes are vinal with an adheasive on one side you soak the car with soap and water and skwegee it out you car get them done if you want look for some where that works on rvs
where are you at?
Old Oct 30, 2003 | 05:21 AM
d-mini-ero's Avatar
d-mini-ero
If you feel ...unsure..have em done professionally
http://www.grafikdezine.com is a great place...ask for phil
Peace,
D
Old Oct 30, 2003 | 11:18 AM
gtshnzr's Avatar
gtshnzr
try matt at cooperflags.com, one of the MCO (haha) sponsors. The stripes come with install instructions and a small squeegee thingy. Easy to do as long as you are patient. I instaled my own graphics and they came out just fine.
Old Oct 30, 2003 | 10:40 PM
kenchan's Avatar
kenchan
wash bonnet with dawn or dish soap solution and dry.
if you're in colder climate, heatup the bonnet with a heat gun.
then apply thin soap solution to both the bonnet and back of
stripe with a spray bottle. apply stripe on the bonnet and position.
then squeegee the soap solution from middle to outward
direction on both sides getting all bubbles from under the
stripe. wipe off excess solution with a lint free towel.
then, get your heat gun again and warm up the stripes
(not hot to the touch) for good 5-6min. let dry for 24hours.
do the other side, wax your bonnet and you're done. :smile:
_________________
03 Cooper-S IndiBlue/Blk: #1 #2 #3, Leather w/ antherasite int, Factory aero kit, R90 w/ SP9000, Alpine 6CD MP3 changer, Autoclearguard. Winter: SpeedEdition TK5 16x7 with Pirelli P6FourSeason 205/50 // 2002 WRX with lots more mods.
Old Oct 31, 2003 | 01:15 AM
OctaneGuy's Avatar
OctaneGuy
It also depends on what kind of stripe you are looking for. The standard bonnet stripes are easy to apply because they sit on the flattest part of the bonnet. Try doing a racing or viper stripe down the center where the bulge is and that's more work. Not to mention having to deal with the emblem. It CAN be done, as you can see here in this pic of my own car. I had a professional sign company do mine.
Racing Stripe Install
Old Oct 31, 2003 | 07:37 PM
White_Knuckles's Avatar
White_Knuckles
Heat guns can be evil on clear coat finish as in blister. Good advice but I recommend application in a heated garage and a Hair Dryer gun to soften the stripe material.
You can use a heat gun on low setting just keep it moving.
Old Oct 31, 2003 | 07:44 PM
Kuneman's Avatar
Kuneman
Overall, what do you guys recommend from everyone who has stripes put on professionally or done personally,
Do I get them done professionally or do I do it my self?
Old Oct 31, 2003 | 09:42 PM
kenchan's Avatar
kenchan
is mini's paint that poor? not that you would need to get the bonnet HOT, but pretty warm to the touch. you can use a hairdryer, but i use a heatgun for all
my decal applications.
ive been working on japanese cars most of my life and never had problems with
blistering clearcoats even at extreme temps... is MINI's paint that weak to heat?
i just want to be sure.
Old Oct 31, 2003 | 10:46 PM
Mini-Matt's Avatar
Mini-Matt
Check our website
http://www.cooperflags.com and under the FAQ section we have a downloadable PDF file that will walk you through the steps and tell you waht tools and supplies you will need to get the job done.
Matt@cooperflags.com
Old Nov 1, 2003 | 02:38 PM
White_Knuckles
Sorry, my comment was for any paint job not MINI specific. Heat guns can be nasty if used by the inexperianced. I have a Milwakee model that messed up the clear coat while trying to remove stripes, of course that was on a Chevy Blazer known for cheezy paint.
I'm sure most people will not concentrate the gun tip in one area for very long but if you do properties of paint can change. I have not tried it on the MINI as it's new and I have a built in fear factor with past results. Your experiance tells the most acurate story. :smile:
STR3T
May 23, 2016 03:27 AM
khumpert
Nov 30, 2015 11:48 AM
Aug 24, 2015 03:02 PM
bctf1
Aug 6, 2015 12:55 PM
