Interior/Exterior DIY R50/R53 Mood Lighting!
Old May 13, 2009 | 04:31 PM
ThomasW's Avatar
ThomasW
http://www.flickr.com/photos/thomaswoodson/3528914201/sizes/l/
I'm sure all of us 1st gen owners are envious of the 2nd gen mood lighting, I sure am. I finally got around to adding some of my own. I put a 10mm blue LED in each door's map pocket. I drilled the holes more forward in the pocket, and close to the plastic trim so you can not see the actual LED. Then I fixed aluminum foil in the inside of the trim to help reflect more of the light back into the pocket.
I ran the LED's off of the existing wires to the door handle lights, thus turning them on when the other interior lights come on (dash lights, door handle lights 05+). All I did was cut the positive wire leading to the orange LED, join it with a wire leading down to the blue LED, then ran another wire back up to complete the circuit, piece of cake.
It would probably look better with a 2nd LED in the rear of each pocket and I will probably do that eventually. I suggest getting the pre-wired LED's from www.oznium.com. I was impatient and bored this week until summer school starts, so I ran to radioshack and got all the raw materials.
I have ordered lights for the footwells, dual 12" blue cold cathodes with a sound activated box. $13 shipped for everything from www.xoxide.com. I would have gone LED but a sound activation module alone was around $15 from oznium plus another $10 at least in LED strips and $5 shipping. I hope they will be in by Friday, but whenever they come in I will install and take pictures on the same day.
I'm currently trying to make a solution to mimic the pillar mood lights of the 2nd gen MINIs. I believe if I get those small plastic pieces that cover the LED's, I can just pop some LED's out and cover them just like factory.
This is what I was going for in the door until I decided it is too much work to try to place them inside the armrest.
Anyone know how to remove the whole silver armrest frame?
Please post your own pictures/questions/suggestions here!
Old May 13, 2009 | 04:41 PM
JohnnyVillan's Avatar
JohnnyVillan
Freakin Awesome
Very inspired to try this out myself. I assume the door panel has to come off to get to the handle light wires?
Old May 13, 2009 | 04:50 PM
ThomasW's Avatar
ThomasW
Yep, have you taken the door panel off before? I've done it a few times and its a piece of cake. You will be able to determine pretty easy where the wires to the LED are, and all you have to do is use needle nose pliers to squeeze the clips and pull it out. Then you trim back the fuzzy insulation wrap so you can cut the wire.
The only time consuming steps were choosing a location to drill for the LED, and also cutting off all my heat shrink tubing when one of the LED's wasn't lighting up...I was almost done too..
It's almost dark out so I can really see how they are working. That shot was in my garage. I can't wait for the sound activated lights to get here. Those shouldn't take much time at all to install. I plan on running the wires into the fuse box. That is how I wired all my mods when I had my Wrangler.
Old May 13, 2009 | 06:09 PM
Malcon's Avatar
Malcon
you sold me.
looks great!
Old May 14, 2009 | 05:03 PM
Act_04's Avatar
Act_04
Taking that whole armrest piece off is a huge pain. You have to remove lots of hot-melted plastic rivet things to be able to pop it all off. Then you have to re-attach somehow. I used plastic epoxy and some luck to put mine back together after painting the silver armrest. The fabric armrest piece comes off with small screws on the backside if I remember correctly.
Looks great how you have it! I might have to try this.
Old May 14, 2009 | 05:23 PM
AggieMini11's Avatar
AggieMini11
OMG. Please post a FULL how too with lots of pics! I love it!!! That would look sick with green LEDs. to match my BRG ofcourse
Old May 14, 2009 | 05:24 PM
ngweibing's Avatar
ngweibing
nicely done
Old May 14, 2009 | 06:17 PM
MUShadd's Avatar
MUShadd
must be nice to have factory lighted door handles...stickin 05+ cars
Old May 14, 2009 | 08:38 PM
chaseabryant's Avatar
chaseabryant
My sentiments exactly... I was riding around in my friends '05 yesterday and was admiring the lighted handles and the little "floods" that shine down onto the center stack.
Any way, the mod looks really cool. I'm jealous. Any reason you went with blue rather than the matching red?
-Chase
Old May 14, 2009 | 08:47 PM
daemon2's Avatar
daemon2
I like the blue, nice touch.
Old May 14, 2009 | 09:17 PM
ThomasW's Avatar
ThomasW
I wanted orange actually to match the orange gauges and stuff but orange lighting is tough to find. Blue is a soothing ambient color and matches well with my hyper blue dash and paint.
I considered taking step by step pictures but then I realized it is too simple. Just read a good guide on the door panel removal then you are good.
Oh I forgot, sound activated cathodes are coming in tomorrow! Pictures will be up tomorrow night and a video too.
I just drew up this quick diagram, all you need to know.
Attached Thumbnails DIY R50/R53 Mood Lighting!-untitled-1.jpg
Old May 14, 2009 | 11:25 PM
MrCooperS's Avatar
MrCooperS
Moderator
oooo pretty light....
Old May 15, 2009 | 02:54 PM
ThomasW's Avatar
ThomasW
Cathodes came...and are installed. Took around two hours mostly because it was hot then started raining, so it was muggy and miserable in my garage. I was laying on my back angled across the floorboard trying to run wires up under the dash, thats about as uncomfortable as it gets. The longest part was figuring out I needed to ground it, haha. I used to run the + and - right in with a fuse in my Jeep, but I ran a + in with the fuse, and ran the ground under a bolt up behind the dash.
It is veeerrryyy cool. . Not as sensitive as I had hoped, but thats probably better for driving. They flutter nicely if I turn the sensitivity all the way up. I'll get pictures and video as quick as I can.
Old May 15, 2009 | 03:34 PM
ngweibing's Avatar
ngweibing
ur on the roll....
Old May 20, 2009 | 01:40 PM
bmwproboi05's Avatar
bmwproboi05
Thats some good work. I would like to see the computer lights when your done
Old May 20, 2009 | 10:23 PM
adrianr's Avatar
adrianr
awesome im going to do it this weekend after mi final exams :S, you might wanna change your dash lights to blue and the needle white it would look awesome, i did something like that to mine just that i only had white leds so i just changed the needle.
Old May 21, 2009 | 07:28 AM
bmwproboi05
you should post pics when you are done
Old May 24, 2009 | 01:48 PM
adrianr's Avatar
adrianr
ok so i started a while ago and i finished the drivers door i started the right door and i noticed one of the led's wasn't blue :( it was red so i had 3 blues and 1 red :S so i have it half done, here are some pics and i'll post more at night when it's darker :p
it really is easy to do mod
Old May 24, 2009 | 05:13 PM
MLPearson79's Avatar
MLPearson79
Love it! I want to do all purple, but I just want to replace all the stock lighting to do it (I have an 06, so I have the waterfall lights and the door handle lights).
Old May 24, 2009 | 07:22 PM
adrianr's Avatar
adrianr
purple will look really nice , for me badly the store was closed today so i went to another one bought a blue led got home just to see it was a different blue xD, so tomorrow morning i'm going to the shop again :p
Old May 24, 2009 | 07:31 PM
xkot's Avatar
xkot
I just order 20 of the blue: http://www.oznium.com/prewired-superflux
We will see where i end up putting them all. I have a 03-R53, so no puddles or handle lights tho. Planning on wiring them from the floor lights. I can do a full DIY post, once I get time.
Old May 24, 2009 | 07:41 PM
justaguyinvegas's Avatar
justaguyinvegas
cool
Old May 24, 2009 | 08:24 PM
adrianr's Avatar
adrianr
nicee i don't live in us so buying stuff on the internet take a while hehehe so i just bought them and wired them myself, good luck post pics of where you added those 20 leds
Old May 24, 2009 | 09:28 PM
xkot's Avatar
xkot
Haha will do, just gotta figure out where to put them all. any ideas?? Air vents..
Old May 24, 2009 | 10:06 PM
adrianr's Avatar
adrianr
under the seats umm cup holders? maybe i dunno xD
