Interior/Exterior What is that thing for anyways?
Old Apr 6, 2009 | 07:18 PM
Dead Ringer's Avatar
Dead Ringer
not sure what its called and if I really need it, but that "ground scraper" under the front bumper, what is it for? Does it keep derbis from going up into the engine? Can I remove it w/out harming anything? I think it car would look a lot better if it was removed, but not if some errant rock will get sucked up and break something...?
Old Apr 6, 2009 | 07:30 PM
orangecrush's Avatar
orangecrush
If you're talking about the vertical piece, (I'm too lazy to go out and look) most cars have a deflector that pushes air up into the lower grille.
I know that on a mustang, if you remove it, the engine will run 15-20 degrees hotter.
Best I can guess without checking it out.
Mark
Old Apr 6, 2009 | 09:01 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
it's an air-dam. It helps prevent airflow from going under the car, and also helps with down force.
Old Apr 6, 2009 | 09:32 PM
Dead Ringer
ok, cool then I will leave it in place
Old Apr 7, 2009 | 05:00 AM
schatzy62's Avatar
schatzy62
And if you would like even more down force check out one of these.
http://www.fastmini.net/mavtefrsp2.html
Old Apr 7, 2009 | 07:06 AM
freez3's Avatar
freez3
From: United States of America, Ohio, Stark County, Uniontown
It let's you know when you're about to ruin your car on a curb.
Old Apr 7, 2009 | 09:50 AM
orangecrush
I'm gonna tell you what my father used to tell me. If the factory thought they could save a buck per car, they would..... considering they produce millions of cars. (and though it's plastic, between parts labor, I assure you it costs more than a buck to produce and install that piece of plastic.
If it's on there, it's on there for a reason.
Mark
Old Apr 13, 2009 | 01:31 PM
dtsoccer6's Avatar
dtsoccer6
Mark
Well put. I feel the same way. If it helps the car and there is no better replacement that improves its purpose, leave it be.
Old Apr 15, 2009 | 02:51 PM
ellinara's Avatar
ellinara
Mark
I agree fully with you to !!! BTW you forgot the price to develop that plastic thing . If you really must change it replace it with something better don't just delete it!!!
patsum
26
May 29, 2021 06:29 PM
riff42
Sep 22, 2015 03:07 PM
cdemarco4
Sep 10, 2015 10:14 AM
Panik
Sep 9, 2015 08:36 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
