Interior/Exterior Covering up steering wheel controls?
Old Jan 27, 2009 | 10:34 AM
morphix's Avatar
morphix
Has anyone tried covering up the steering wheel controls on a 3 spoke wheel from a 06 MCS?
Put in a new radio so they are no longer functional, even tried to install the PAC SWI-Jack with no luck.
I'd be happy just to cover up the one side (left side with the two buttons and thumb pad thing).
https://www.outmotoring.com/mini-coo...heel_trim.html
These look like the will work but before I spend the $35 + shipping are there any other options out there?
Old Jan 27, 2009 | 11:30 AM
rkw's Avatar
rkw
The single cover is part # 32306765093, according to realoem. Check if Classic MINI has a better price.
What headunit did you put in? newministuff might have something that works with the buttons.
Old Jan 27, 2009 | 12:23 PM
morphix's Avatar
morphix
it is an alpine CDA-9884, the adapter should have worked but I just had no luck installing it.
I don't use the controls anyway.
Any idea what would be involved in installing this cover?
Old Jan 27, 2009 | 01:11 PM
morphix's Avatar
morphix
how in the hell do I remove the paddle shifters to gain access to the screw?
edit:
never mind you don't have too, I feel so stupid
Old Jan 27, 2009 | 01:34 PM
Q-4000's Avatar
Q-4000
what color are they? ill trade you mine for yours with the controls and wireing! i dont have the steering wheels controls
Old Jan 27, 2009 | 02:18 PM
morphix's Avatar
morphix
they are grey but I am only removing one side and not going to take out the wiring. Sorry.
Old Jan 27, 2009 | 02:56 PM
rkw's Avatar
rkw
The part# I gave earlier was for a regular steering wheel. For one with paddle shifters, it is part# 32306765093.
The proper way to remove spoke covers is to take off the airbag. Instructions here. I've heard of people who managed to pry off a spoke cover without removing the airbag, although not one with buttons. You probably need to remove the airbag anyway to unplug the cable attached to the buttons.
Old Jan 27, 2009 | 03:23 PM
OctaneGuy's Avatar
OctaneGuy
With the screw removed (I don't have the paddles) the front covers come out without removing the airbag but it's very difficult as the portion of the cover under the airbag needs to be forced pretty hard.
Removing the airbag isn't difficult, and the holes you make for removing the airbag aren't that visible. I hated the thought of cutting the holes, but over time, they "seal" back up so you don't notice them until you're looking for them.
Releasing the airbag can be extremely frustrating, especially if you're successful in removing one side but not the other-there are two spring clips that hold the airbag in place. You need to shove a screwdriver, blindly down a channel and push that spring/lever away until it releases the airbag. Because you have to press pretty hard, it's a little nerve wracking that you might be tearing something up inside, but there is nothing there but cast metal.
Remember to cut the power from the battery before removing the airbag.
Richard
Old Jan 27, 2009 | 03:27 PM
morphix's Avatar
morphix
that is the same part #
I guess it doesn't matter.
The old one just popped right off did not have to remove the airbag, with a little love the new piece one should work out <crosses fingers>
Old Feb 17, 2009 | 03:23 PM
morphix's Avatar
morphix
well I was away in NYC but got back this morning and fixed my steering wheel.
since I did not remove any of the old hardware so I can reverse it later, I ended up trimming the attach points off and using a few layers of thick mounting tape to attach the cover. Worked like a charm
theblackfalcon
Oct 11, 2015 09:49 AM
Powershift
Aug 16, 2015 05:14 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
nismo4life
Aug 5, 2015 08:31 AM
