Interior/Exterior Just painted my Brakes (Not Slow Connection friendly)
Old Sep 2, 2008 | 07:34 PM
SomethingNew71's Avatar
SomethingNew71
Check out the in the process pix!
Old Sep 2, 2008 | 07:55 PM
checkercoop's Avatar
checkercoop
Good job! I take it you used the G2 orange kit? I used that on mine and yours seems to be the same texture.
Old Sep 2, 2008 | 08:17 PM
SomethingNew71
I actually used the Red Duplicolor Kit. Probably about the same either way.
Old Sep 2, 2008 | 11:25 PM
Robin Casady's Avatar
Robin Casady
Did mine as well.
Old Sep 3, 2008 | 08:17 AM
rockridge's Avatar
rockridge
I like the orange look! I need to paint mine again, as they started to peal from a pressure washer gone wrong incident.
Old Sep 3, 2008 | 10:49 AM
maximus96's Avatar
maximus96
do you guys paint the calipers while their still on or do you remove them first? when i did my maxima with high heat spray paint i removed everything from the car. it end up being more of a pain having to bleed the lines and everything. also, how does the paint hold up over time? with the high heat spray paint i used they all end up cracking.
Old Sep 3, 2008 | 10:58 AM
uniqueMR
Guest
Posts: n/a
great job!
Old Sep 3, 2008 | 01:03 PM
Robin Casady
Did them while on the car.
Old Sep 3, 2008 | 01:18 PM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
I used the same kit. I ended up with quite a bit of left over paint after 3 coats. Looks Good!
Old Sep 3, 2008 | 02:27 PM
maximus96's Avatar
maximus96
how do you manage to not get any paint on the other parts, like the brake pads and such. does the paint run when you paint it on?
Old Sep 3, 2008 | 02:33 PM
Oxybluecoop's Avatar
Oxybluecoop
Looks great!
Old Sep 3, 2008 | 02:46 PM
Oxybluecoop
I removed the calipers and disassembled to paint with Duplicolor Caliper Paint.It holds up fine given you cleaned the calipers REALLY GOOD before you paint them.Gravity bleeding the lines is pretty simple.I've sprayed mine repeatedly with high pressure and the paint holds up.
Old Sep 3, 2008 | 02:48 PM
SomethingNew71
Many very very light coats. When you go really light each time there is no problem of driping. So like when you paint just have very minimal amounts of paint on the brush.
Old Sep 3, 2008 | 07:36 PM
checkercoop
Also use masking tape on all the parts you don't want painted. Cover the lines, pads, and those clips. The G2 stuff is really thick, goes on smooth, and leaves a hard layer. I can take my finger and easily wipe off brake dust because it just cannot get caked into this stuff. The chemicals are also made for the heat and they guarantee it for life. If you were to ever get a chip, all you have to do is send them a pic of it and proof of purchase and they send you a whole new kit for free
Old Sep 19, 2008 | 07:47 PM
toolazyforalogin's Avatar
toolazyforalogin
I posted this in a similar thread but in case you're subscribed here and not there does anyone have any detailed pics of what I should be painting vs. what I SHOULD NOT be painting? I see SomethingNew's pics above so I can try follow that but would prefer a better description if possible. Thanks.
i.e. the lines pads clips that checkercoop is talking about
Old Sep 19, 2008 | 08:04 PM
checkercoop
Here is the best pics I have of it all
Besides the rotors, you can see in these 2 shots of the fronts some of these things that are covered
This is with the tape off so it can show some spots that had paint on top the paint (the clip I was talking about can be seen by: follow the rotor around from the top...right below the first section of the top side of the caliper is a black metal clip running horizonal...it is best to tape that off)
Heres the rear caliper taped off
And here without the tape. You can see 3 black sections. All 3 were covered with tape. The middle is the break pad wear sensor (only on 1 side) and the 2 outerside black sections are the clips I was talking about
Goodluck
Old Sep 20, 2008 | 01:52 PM
toolazyforalogin
Like usual, you have the info I need. Thanks again. Now I just have to wait for nice weather and an open weekend.
How many coats did you do? 3 ?
theblackfalcon
Oct 11, 2015 09:49 AM
imanexcellentdriver
Aug 31, 2015 08:08 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Aug 12, 2015 01:24 PM
