Interior/Exterior I was hoping the mudflaps would work better...
Old Aug 23, 2008 | 01:54 PM
minim8o's Avatar
minim8o
...ok, they performed somewhat admirably as the whole door would have probably been splashed w/o 'm, but you can see there's room for imporvement!
I don't recall where & when I picked this mud up. Being on the wrong side of the car, that I rarely look at, I'm sure it had been there for a while before I saw it.
Old Aug 23, 2008 | 04:14 PM
motionmonk's Avatar
motionmonk
Enjoy it... it's a badge of honor!
Old Aug 23, 2008 | 07:38 PM
minim8o's Avatar
minim8o
hahah, ya, right!
I prepared another image with a 'high-key' tratment from a very under-exposed one. Might as well post it:
Old Aug 23, 2008 | 07:42 PM
Ryephile's Avatar
Ryephile
Looks like they work better than not having anything there! I just wish they blended into the body lines better than they do [especially the rear flap].
Old Aug 23, 2008 | 09:24 PM
sailorboy's Avatar
sailorboy
Doesn't look like they do that much. I was thinking about adding some to my rear wheels in an attempt to keep the rear winshield cleaner.
Old Aug 25, 2008 | 04:53 AM
schatzy62's Avatar
schatzy62
Originally Posted by minim8o
hahah, ya, right!
The only way to get them to reduce the mud any more is to lengthen them. If they were longer (hung down fathrer) then there would be less mud on the car.
What you may be able to do is to buy some generic ones from the local auto parts store and cut a few inches off the bottom of them and add it to the Mini ones.
The only problem with longer ones is them getting hung up on something after your tire drives over it, and unless you are driving over curbs or something like that it should not be much of a problem.
Old Aug 25, 2008 | 04:20 PM
Tu13es's Avatar
Tu13es
Wow, I love this pic. Any special camera/lens here?
Old Aug 25, 2008 | 06:01 PM
minim8o's Avatar
minim8o
Thanx. I definitely think the MINI likes the super wide-angle lenses than long telephotos; latter serving to flatten the perspective the longer lens you use, resulting in the car looking too squat.
I use a Pentax K10D. The lens is the much loved DA 12-24mm f/4, even if it does suffer from a lot of CA and purple fringing if you have high contrast portions in the image until stopped down about two stops or more. I shoot RAW a lot now as I do a lot of work in post [in Lightroom] balancing an image but still making it 'pop'. The image was shot @ 15mm, f/6.3, ISO400, 1/60 sec.
Old Aug 25, 2008 | 06:11 PM
minim8o's Avatar
minim8o
Example of "too squat": (notice how 'flattened' the image looks)
For this image I used one of my favorites, the Voigtlander 125mm f/2.5 (a manual focus lens of exceptional quality), coupled with the Pentax 1.7x AF Teleconverter... turns manual lens into a auto-focus lens! 1.7x applied to 125mm making it a 212mm lens!
W0TM8
Dec 19, 2019 07:50 AM
blackie
Sep 2, 2015 09:16 PM
David.R53
Sep 1, 2015 06:49 PM
R53Mom
Aug 17, 2015 01:38 PM
yashmack
Aug 15, 2015 03:11 PM
