Interior/Exterior bonnet/boot Mini stripes question??
Old Aug 20, 2008 | 08:17 PM
fflan513's Avatar
fflan513
My stripes arrived, ordered from mightstripes.com. The stripes are on a backing material but they have no clear plastic covering the stripes; has anyone worked with stripes such as these? Is it normal for there to be no clear plastic covering?
Old Aug 20, 2008 | 08:28 PM
cabriopilot's Avatar
cabriopilot
Are you 100% positive that there is no backing material?
If there isn't I would be extra careful in applying them to your MINI.
The stripes that I received from Aestheticreations.net had a semi-transparent film on top.
Without that layer it would be very difficult to apply without scratching the surface layer.
Old Aug 20, 2008 | 09:50 PM
fflan513's Avatar
fflan513
If there is a semi-transparent film on top it is the exact same size as the stripes and I can't see it. I will cover my squeegee with a cloth when applying to be extra careful. Anybody got any other recommendations? This is my first time applying stripes.
Old Aug 21, 2008 | 04:05 AM
cabriopilot
Well based on their instructions there must not be an outer film to remove, because its not mentioned in the instructions.
I have only done dry applications so I guess with the wet method an outer layer is not required.
Here's their instructions: MINI Cooper Bonnet and Boot Stripes (Wet Application)
Good luck and remember to take your time and don't rush it.
Old Aug 21, 2008 | 05:00 AM
fflan513's Avatar
fflan513
Instructions....hmmm
Yeah I saw that BUT the instructions (see attached file below) that came with the stripes reference a "pre-mask"; last time I use mightystripes, they aren't making his easy for a newbie. lol
File Type: pdf
Old Aug 21, 2008 | 04:16 PM
fflan513's Avatar
fflan513
Stripe installation progress
Well, I installed the bonnet stripes and they look great if I must say so myself.
The lack of transfer tape made no difference, hopefully the boot and bumper stripes go as well. When I finish I will post pics for NAM critique.
Old Aug 22, 2008 | 12:53 PM
maximus96's Avatar
maximus96
any tips on how to align the stripes straight and centered? i'm looking to put viper stripes when mine arrives. it'll be on the front bumper, bonnet, roof, boot, rear bumper. how do i ensure everything is lined up correctly?
thanks
Old Aug 22, 2008 | 02:49 PM
fflan513's Avatar
fflan513
String
thanks
I used string (taped to Mini) to divide the car in half from front to back using the antenna and "Mini" emblems as reference points and then I measured and marked points with a grease pencil. Really glad I did it myself, saved about $250.00. The guy that did my tint job wanted 350.00 to do the stripes. I'll post pics tomorrow.
Old Aug 23, 2008 | 01:26 PM
fflan513's Avatar
fflan513
DIY Stripe PICS
Well these were the first (and only) stripes I've ever installed, wasn't as difficult as I expected, saved a wad of cash and got that DIY feeling. Check it out:
Attached Thumbnails bonnet/boot Mini stripes question??-091753-r1-10-10a.jpg   bonnet/boot Mini stripes question??-091753-r1-11-11a.jpg
Old Aug 23, 2008 | 02:17 PM
cabriopilot
Now that looks sharp! You did a great job on the stripes.
Only thing left to do is get rid of that nasty advertisment for Moritz on the boot.
Unless of course they are helping you with your monthly payment.
Old Aug 23, 2008 | 02:59 PM
fflan513's Avatar
fflan513
I have strongly considered removing the Moritz stuff (plate bracket as well). You know that's not a paid endorsement!
And thanks for the Kudos
Old Aug 23, 2008 | 04:41 PM
cabriopilot
Nothing against Moritz, I actually like the Youtube video they have of a MINI just like mine.
The only bad thing is that the longer the decal is on there the harder it gets to remove the glue
that it leaves behind and in some cases the paint may fade at a different rate leaving a shadow.
Old Sep 12, 2008 | 02:07 PM
toolazyforalogin's Avatar
toolazyforalogin
Great install of those stripes.
Old Sep 16, 2008 | 04:49 PM
ubdylan's Avatar
ubdylan
Came out great! Do they have wider ones available? I just stripped my stock stripes off and I'm rolling naked for a bit. I kinda like the blank canvas at the moment.
Old Sep 16, 2008 | 06:30 PM
fflan513's Avatar
fflan513
Yes they have wider stripes and they also do custom orders; so it's what ever you like. Check out:
mightystripes.com or http://www.aestheticreations.net/index.htm
and thx for the kudos
Dec 23, 2015 10:36 AM
minicoclub
Aug 25, 2015 09:07 AM
bctf1
Aug 6, 2015 12:55 PM
OutMotoring
Aug 6, 2015 09:32 AM
