Interior/Exterior DIY blackout HL & TL rings - grill surround R56S guide
Old Jun 25, 2010 | 08:33 AM
  #251
combfilter's Avatar
combfilter
Originally Posted by -=gRay rAvEn=-
It's not spray paint though.
When you have a few minutes, go over the directions on the can.....PD is totally different. Layers have to be applied within a certain time frame, and CANNOT be applied in direct sunlight. Find a shady cool spot like a garage or basement
Yeah I definitely read the instructions before i started. They say do layers (4-5 according to their faq) holding the can 12-16" away (per back of can). This is what I did. All my pieces get that peach fuzz on them. I really think it's the heat and humidity. There's no such thing as finding a "cool shady" spot here in DFW in the summer. average summer day is basically 100 degrees w/ 50-60% humidty.
I've been doing them in my garage with no wind, but again the heat and humidity is out of control here. I am going to try to somehow rig up a system in my extra half bathroom at my house.
I know this should be super simple, but you've seen my results. I'll see how my homemade spray booth works inside my AC'd house.
Old Aug 18, 2010 | 02:28 PM
  #252
jpadilla128's Avatar
jpadilla128
Originally Posted by combfilter
I don't know if it's the heat and humidity 100 degrees with like 40-50% humidity.(in which faq on plasti-dip's site says , do not use in high humidity), but i am having horrible luck getting my plasti dip smooth looking. I have done the gas cap like 3x's now and it always starts to bubble up kind of peach fuzz looking texture. Are you guys some how sanding it between coats?
My technique that so far is not working
1. clean chrome part with mineral spirits and then ammonia free glass cleaner
2. do not touch it with my fingers once clean
3. first coat, I hold the can 12-16" away and spray in strokes and lightly cover the chrome piece with a light coat
4. wait 30 minutes and come back and spray from 12" away and lightly cover the chrome piece again. This is when I see this peach fuzz type texture appear
5. wait 30 minutes and do the same thing as step 4.
6. come back and get pissed that it's all fuzzy and wonder if it's the heat and humidity here in texas
7 strip off plasti dip with mineral spirits and try again.
I am using the spray like i was spray paint anything else. Very smooth strokes not letting off the nozzle till I am past the piece i am painting during my stroke.
I am getting the same results you are. I gave up... after 3 attempts.
I'm going to try Duplicolor Trim paint.
Old Aug 18, 2010 | 02:29 PM
  #253
jpadilla128
BTW I don't think the weather has anything to do with it. I did it in my garage with little humidity and an 80 degree day.
Old Aug 20, 2010 | 11:27 PM
  #254
Jrpsaros's Avatar
Jrpsaros
On the Plastidip website, they sell a spray, and a paint on. Has anyone tried just painting the visible chrome with the plastidip?
Old Aug 22, 2010 | 12:30 AM
  #255
miniworkshop's Avatar
miniworkshop
Has any one fitted with carbon type before?
Old Sep 6, 2010 | 07:36 AM
  #256
VelvetFoot's Avatar
VelvetFoot
Just thought I express my appreciation for this thread. I'm not into modding, but I did stupidly drop a tailight bulb and it's holder and couldn't get it after hours of trying with skinned knuckles. After reading this thread how to remove the taillight, it was a breeze. Thanks much.
Old Mar 30, 2011 | 06:19 PM
  #257
Richieb0y28's Avatar
Richieb0y28
Hey guys, i still need to do my front grill but i've been nervous about removing it. Has anyone had any issues taking off or putting on either the top or bottom portion? I also want to black out the side scuttles too, has anyone had any issues removing those? Is there anything I should know before plasi-dipping them? Thanks
Old Mar 31, 2011 | 10:54 AM
  #258
tjtull's Avatar
tjtull
I bought a new black grill surround from someone (can't remember offhand who it was) but when I was removing the original chrome pieces, I broke two clips. They don't come off easy, yet are easy to break, so be careful.
Old Mar 31, 2011 | 07:19 PM
  #259
SooperCuperErik's Avatar
SooperCuperErik
Try 6 inches and a heavier coat. Being 12 inches away and lightly covering is causing it to be scattered. If you're closer and spray a heavier coat on until you see it "wet" you'll notice better results.
Old Sep 6, 2011 | 01:11 PM
  #260
Brad Bedell's Avatar
Brad Bedell
I know this is an old thread, but this issue is solvent pop. In the most basic of definitions: the outer layer is skinning over and the under layer is boiling out.
Reduce your temps or change your frequency of coats. Most paints are dry-time rated at 70f degrees. For every 10 degrees it gets hotter, you cut the dry time in half, for ever temp cooler, you double it. Under about 50 degrees your chemical reactions more or less stop. This is ambient temps or surface temps. A few years ago, I had to completely repaint a car that I had just painted because I rolled the car out into the sunlight too early.
If one has an attached garage, open the door to the house, turn a fan on and, let the AC cool it down. *or* do like me and put a 2 ton window unit in the garage and not sweat it.
Old Sep 10, 2011 | 06:01 PM
  #261
dez's Avatar
dez
one of the black clips was eatin by the engine bay. Think it will be secure enough missing one?
Old Sep 19, 2011 | 04:34 PM
  #262
BP K9 Miami's Avatar
BP K9 Miami
Originally Posted by tpmini
Done! Should I get black wheels next?
There's a very good video on YouTube which shows some guy doing his rims with Plasti-dip on a Tahoe...you might want to shoot one of yours first. It might save some $$ and it appears like a straight forward DIY job.
Old Sep 19, 2011 | 04:40 PM
  #263
BP K9 Miami
I finally got around to tackling this project this weekend. Following the instructions here ( and not less then a half-dozen of the lessons learned ) everything went fine. Despite this being one of the older threads, it's stuff like this that make this community special.
EDITED and added some photos. . . easy project following all the advice.
Thanks.
Attached Thumbnails DIY blackout HL & TL rings - grill surround R56S guide-img_1110.jpg   DIY blackout HL & TL rings - grill surround R56S guide-img_1111.jpg
Old Oct 2, 2011 | 06:12 PM
  #264
MINIopoly's Avatar
MINIopoly
just finished painting my hl's/tl's and grille. i looks sick
im doing the beltline right now then the handles and gas cap
how do you take the gas cap off the car?
thanks
Old Oct 2, 2011 | 06:15 PM
  #265
MINIopoly's Avatar
MINIopoly
i lost 5 1/2 of the black clips to the engin bay:(
i have to go to the dealership and get more, i might also check the coupe
Old Oct 30, 2011 | 10:53 PM
  #266
bokchoiboi's Avatar
bokchoiboi
To take off the gas cap, there is a tab on the upper inside of the gas cap. Pry outward and rotate the gas cap at the same time. The gas cap should break free afterwards.
Here is a video on how its done.
http://www.youtube.com/watch?v=TDrOy...layer_embedded
Old Oct 30, 2011 | 10:55 PM
  #267
bokchoiboi's Avatar
bokchoiboi
Also found an alternate way to remove the tail light rings. Instead of a small screw driver, I used the corner of a credit card. Just slip the corner in between the ring and the tail light, bend the card slightly for more leverage and pry gently. You will hear the clips pop one at a time. Repeat this around the light and the entire thing will be off in no time.
Old Nov 8, 2011 | 12:02 PM
  #268
olib1990@talktalk.net's Avatar
Clear coat over plasti dip
Hi, im from the UK but this topic seems to be much more discussed on this American forum... so here i am
I am also looking at painting my headlight rings, grille surrounds and spotlights black with plasti dip. But i want to make them gloss black, according to the plasti dip UK website http://www.plastidip.co.uk/eStore/in...oating&stage=1 you can apply this clear coat and it does it. Im assuming since it comes in a tin you paint it on.
Has anyone used or heard of using this?
Old Nov 8, 2011 | 02:20 PM
  #269
blackjack11's Avatar
blackjack11
+1. I had similar results when "dusting" it form far away. Moved closer to achieve the "wet" look and all was GTG. Don't give up!
Old Mar 26, 2012 | 07:57 PM
  #270
mikeyb74's Avatar
mikeyb74
I so want to black out all the chrome bits on my MCS. But not sure if I should use plasti dip or factory Jet Black 668 to match the roof and mirror caps? I already have two spray cans of the Jet Black from when I owned a Jet Black e46 325xi. What do you guys think?
Headlight rings, side scuttles, A-panels, door handles, fuel door, tail rings, boot lid grip, and hood scoop are what I want to paint black.
Does the plasti dip match the black trim already on the car?
Old Apr 20, 2012 | 07:31 PM
  #271
fherrle's Avatar
fherrle
mikeyb74,
Hi I am new to all of this mini mod's
I am currently blacking out my 09 chili red Hard top. I am doing gloss black to match the top. I thought about the plasti-dip, but I did not want the flat look.
I am stripping the chrome off of the plastic myself. Regular paint does not stick very well to chrome.
I think it may take me a bit longer but the end result will be much nicer.
To strip off chrome all you need is a bucket that the parts will fit into and some bleach. I have some pool type that is 2X stronger than house hold bleach. I found the info on a model car forum. After the process is complete I should have a clean raw plastic part ready for paint.
I will post more as I progress.
Old Apr 22, 2012 | 09:05 AM
  #272
JCWR56's Avatar
JCWR56
Thank you, this has been very helpful!
Old May 6, 2012 | 07:39 PM
  #273
mikeyb74's Avatar
mikeyb74
So...I went to tackle this DIY today. It was in the high 60s and sunny when I did this. Everytime I sprayed the chrome bits there would end up being spots that would bubble like there was to much sprayed on the parts. I followed the directions on the back of the can. Luckily I could peel off the plastic dip. I take it there is a learning curve to spraying paint. I've never really used spray paint. Rustoluem on step bars and a brush guard does not really count. So I'll be trying this again this coming weekend.
Old May 7, 2012 | 08:14 AM
  #274
fherrle's Avatar
fherrle
Update on my black out.
So the bleach did not work as well as I had hoped.
Plan B: I have connections at a local plating shop, they were able to soak off the chrome in the nitric acid tank.
this worked very well, I have fresh plastic parts to lay down my paint. I had one part that the clips had broken off so I was able to test on this one first.
NOTE: best to remove all of the plastic tabs, I left the one that screws go into and they melted away, different kind of plastic.
I had to strip and repaint the headlight rings, I got in a hurry and the paint was not fully cured, left fingerprints. we finnaly have weather in the 70's so I am hoping to have finished in the next week.
The wife keeps giving me a bad time about my car missing parts and looking like crap.
Old May 8, 2012 | 12:12 PM
  #275
JPR18's Avatar
JPR18
Just dipped my TL rings today on my '12 MCS
I used the credit card method, which I recommend. Take an old plastic card and wedge the corner up against the clips, and it will pop right out.
And this is what you'll see:
New on the left, old on the right:
both done:
detail:
