Interior/Exterior Removing a-panels?
Old Mar 30, 2008 | 02:51 PM
DME's Avatar
DME
Removing a-panels?
Is this do-able w/o being a body shop? Some nitwit hit my car a few weeks ago and I'd like to try and replace my driver side (EB) A panel with one off a parts car rather than have the body shop mess with it.
(caveat - I tried to search but the phrase 'a panel' makes it worthless)
Thanks!
Dave
'04 MCS EB/W
Old Mar 31, 2008 | 04:19 PM
Goodwood's Avatar
Goodwood
easy
just bought an '03 CVT that needed this part replaced... bought a new part at the dealer for about $58...
very easy to install, be sure you save the foam strip off the old one (or don't destroy it when removing the old one... it's a long strip that acts as a pad and a seal... it runs from top to bottom parallel to the inner (windshield) side of the pillar... and it's stuck to the windshield and your old part.
pull back your weatherstripping that seals driver's window and door, right next to the part you're replacing... along the A pillar... you'll find 4 screws that hold your part in place.. remove them then slowly pry the old part off... it's also held on by plastic pointed things that stick into holes in the metal part of the A pillar... similar to what's used to hold door side-moulding onto a door.... you might very well break the old part into several pieces trying to pry these things out... that's what happened to me, but I didn't really care since the old part was cracked already... that's why I was replacing it.
'03 Velvet Red w/White Top CVT K&N in the airbox, my only mod.
if you're trying to remove one from another car to use on your car, you'll have to be very careful that you don't break it as described above, when trying to pry those pointed plastic things out of the A pillar metal.
Hope this helps.
Old Apr 1, 2008 | 06:15 PM
chaseabryant's Avatar
chaseabryant
are you talking about your a-pillar cover, or the panel that the vents and side signals are in? If you are asking about the latter, I found it to be very difficult, the torx bolt that was holding it on was actually painted on, so I was unable to remove it because of lack of proper leverage. According to my bentley manual it is removable. If you don't have one, you should buy one and if you do have one, it says inside how to remove it.
-Chase
Old Apr 2, 2008 | 03:52 AM
Goodwood's Avatar
Goodwood
I'm talking about the black glossy plastic cover on the A-pillar, between the hood and the roof.
Old Apr 4, 2008 | 04:25 PM
chaseabryant
I was making sure what the original poster was asking about.... I knew what you were talking about!
-Chase
Old Apr 4, 2008 | 04:58 PM
xnotfunkylex's Avatar
xnotfunkylex
Considering it got hit by a car I would say that it is the a-panel. The part with the side vent in it.
Old Apr 4, 2008 | 05:01 PM
xnotfunkylex
Looks doable at home. Looks like there are only a few bolts/screws holding it on. Maybe you could ask Gnatster because he has switched his panels for new ones, so he should know what is involved.
Old Apr 4, 2008 | 05:02 PM
Goodwood's Avatar
Goodwood
My mistake
Sounds like I was mistaken in my initial reply. I've never heard it called an A-panel. I would have called it the front fender.
Too eager to share my recent experience with an A-pillar I guess.
Old Apr 4, 2008 | 08:01 PM
xnotfunkylex
No worries. I just recently saw another thread on the a-pillar recently. I hope I don't have any issues with mine.
Old Apr 5, 2008 | 12:39 AM
Berthil's Avatar
Berthil
Removing the side-panel is not hard. I replaced it and made a few picture. Commentary is in Dutch but the pictures may help.
One bottom screw was the hardest. It was so tight it had to be flexed of.
Don't try to bend the side-skirts to reach the bottom screw if they are from the aero kit. The skirts will crack. Get a set of new clips and rip them of.
http://www.r53.nl/zoekfoto.php?from=23722383
UncDeo
Nov 4, 2019 04:08 AM
BRracing
Oct 24, 2015 10:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
broncobuddha
Sep 1, 2015 06:32 PM
