Interior/Exterior Grille suggestions
Old Dec 22, 2007 | 03:34 PM
ronmichael's Avatar
ronmichael
Grille suggestions
I have an '06 MCSc with the chrome line package. I like the chrome but I'm starting to find that I don't like all the chrome on the grille. It seems to make the car to conservative, almost like a Benz. The aero kit grille is interesting but I find it doesn't have enough chrome. And I don't really like a lot of the 3rd party grilles, like the M7; I love M7 but I find their grills too metallic and harsh looking.
I think what I ideally want is chrome around the grille, but the slats or grid inside the grille to be black. So I guess I want to either de-chrome the chrome slats in my grille or get a aero kit grille that is chromed around the edges.
Any suggestions on how I might do either? Can you remove the chrome that covers the horizontal slats of the standard MCS grille? Or find an aero grille that is chrome around the edges?
Thanks!
Old Dec 22, 2007 | 06:49 PM
rkw's Avatar
rkw
I have an OEM black grill and it is reasonably priced: https://www.northamericanmotoring.co...33754/cat/1147
Others have painted or applied black vinyl to the slats with good success.
Old Dec 22, 2007 | 07:46 PM
H.A.W.G.'s Avatar
H.A.W.G.
Is there a Aero Kit grill with the chrome edges, that is what I have always wanted , but I do not know if one even exist
Old Dec 22, 2007 | 08:50 PM
hunter99's Avatar
hunter99
You are not the only one. I am probably going to the Aero front bumpur soon but I don't like the Aero grill. One with chrome edges would be perfect but I have yet to find one. I am buying a grill from someone else and just going to use he stock chrome lower grill with the normal grill on top.
The best I ever have found is a stick on chrome one at Minispeed and Moss Mini but you still need the regular grill under it.
Old Dec 23, 2007 | 11:37 AM
H.A.W.G.'s Avatar
H.A.W.G.
I wish M7 would make their grills smaller for inside the Chrome.
Old Dec 23, 2007 | 11:43 AM
ronmichael's Avatar
ronmichael
Great. This actually sounds like the best solution for me. It looks like popping out and replacing the bonnet grille is pretty simple. What about the upper bumper grille slat?
Old Dec 23, 2007 | 12:57 PM
flaco's Avatar
flaco
You might check out GrillGuy or GrillCraft and make your own.
Old Dec 23, 2007 | 01:41 PM
rkw's Avatar
rkw
Removing the bonnet grille simply involves taking off the nuts, but if you want to sell or preserve your chrome grille it's a bit tedious to remove the nuts while minimizing damage to the soft plastic posts they screw onto. A 10mm hex socket on a screwdriver style handle works well for turning the nuts.
The bumper grille single slat is attached with double stick tape. Use a hair dryer to help loosen and lift up one end of the slat, then slip dental floss under it and pull to cut through the tape.
Old Dec 23, 2007 | 02:00 PM
FP's Avatar
FP
Yep, this is what I did as well. I also would love to have chrome around the aero grill. I don't like it all black. I'm surprised no one has come up with one.
Filmy
15
Jun 6, 2023 06:27 AM
triple955
Sep 16, 2015 07:50 AM
Sterling Thompson
Sep 9, 2015 07:55 PM
