Interior/Exterior Sunroof Graphic - White/Clear Squares?
Old Dec 9, 2007 | 03:36 PM
TopGunner's Avatar
TopGunner
I'm looking for a checkered graphic for my sunroof that would mimic the OEM graphic. I have the OEM graphic, but it's already becoming an issue because it's composed of individual white squares, and the sunroof itself makes the black squares. 6 weeks old, and there are already some corners lifting up!
Anyway, it's my understanding that the after market checkered graphic is one solid sheet of vinyl (this would be good!), but is composed of white vinyl with black squares printed on it. Thus, it gives a stained glass look from inside. I really, really like the look of the OEM graphic from the inside of the car... the clear openings in the graphic look so sweet!
What I would love to find is someone that makes a roof graphic composed of a CLEAR vinyl background with WHITE squares printed on it. This would look identical to the OEM graphic without all of the edges!
Does anyone know if this is made by anyone, or can it be custom made?
Thanks!
Old Dec 9, 2007 | 05:45 PM
CooperGear's Avatar
CooperGear
From: Greater Chicagoland. Ich Bin Ein Midwesterner!!!
Who did the install on your graphic? Sounds like it was not done correctly. I have some vinyl on my car that has been on there for over a year and there is no lifting of the corners. The one time I had a problem is when I had some text that came to a VERY acute point and that was something that was temporary for Halloween.
I have never had a 90 degree corner peel. You also can not wash the roof as you would if you did not have the vinyl, you must be way more careful.
You can have a perforated graphic made up by Mike from Aesthetic Creations, (check the vendor directory.) It will be white perforated vinyl that is printed with the black checker squares. I have never seen white and clear and not too sure how good it would look anyway.
Hope that this helps.
Blake
Old Dec 10, 2007 | 11:19 AM
rattmobbins's Avatar
rattmobbins
I got the perforated checkered sunroof graphic from AC with black and white checkers, and you can't even hardly tell there is anything on there from the inside. Highly recommended.
Old Dec 10, 2007 | 02:47 PM
TopGunner's Avatar
TopGunner
That sounds great, except that I really want to see the checkered pattern from the inside - and I won't be able to with the perforated graphic.
Also, when the sun shines outside, I get a checkered shadow on my floor, and I can see a checkered reflection in the stick shift - it just looks sweet to me.
I'm afraid that if I get the solid vinyl, I won't the checkered shadow or the reflection - that's why I thought a clear vinyl graphic with white squares would be perfect.
Here's another thought - could you put the OEM graphic on and overlay it with a nearly clear tint - or with the 3M protectant?
Old Dec 10, 2007 | 03:05 PM
CooperGear's Avatar
CooperGear
Don't think that would work too well. Who did the original install? You? I would stick to the solid vinyl squares. I did my buddies roof graphic and he is not careful at all about caring for it. No peeling at all. Did you clean any wax off the surface of the sunroof when prepping? This could mess with the adhesion of the vinyl.
As thin as the antennas on the Sears Tower and Hancock building are. (less than 1/8" at the point,) they are not peeling back.
Old Dec 10, 2007 | 06:37 PM
TopGunner's Avatar
TopGunner
Dealer Installed...
I purchased it when I ordered my MINI. The graphic came from the factory, and was installed at the dealers.
I'm having them look at it this Friday - I guess I was just considering whether I should have them replace if with the same graphic, or if there will be on-going issues, should I get a solid graphic and have them install it (thus saving me the cost of installing a different graphic.
Old Dec 10, 2007 | 06:57 PM
VicSkimmr's Avatar
VicSkimmr
I would go aftermarket and get someone else to do the install.
Old Dec 10, 2007 | 07:07 PM
TopGunner's Avatar
TopGunner
I might as well let the dealer take care of it as long as it's free... once it's not covered, then I'll go aftermarket for installation.
Old Dec 10, 2007 | 07:28 PM
CooperGear's Avatar
CooperGear
I say take it back to the dealer and make them re-do it. Then if it peels again make them re-do it again until they get it right. They should be made to stand behind their work. Any quality installer will warranty the install for X amount of time. If the vinyl is done correctly is is not easy to take off.
Good luck to you.
Old Jan 9, 2008 | 08:58 PM
Carve906's Avatar
Carve906
To revive this old post...is there such a ^^ sunroof/roof graphic ^^ available?
If not, can someone post pics from inside on one of the perforated full vinyl sheets?
Thanks!
Old Jan 11, 2008 | 01:08 PM
giantjoe's Avatar
giantjoe
Go to your local sign shop. If they do any vinyl at all they will have done something on a car. They can print a clear vinyl with checkers on it. They can install it in less than an hour [after the ink dries]. One piece, no lifting.
On another note...
Can somebody with perf take a picture of their sunroof from the inside so I can see if I want to do it. I like my blue stripes on the roof but I feel a little trapped in my car.
Old Feb 20, 2008 | 02:28 PM
caulyne's Avatar
caulyne
On another note...
Aesthetic creations website has this: http://aestheticreations.net/graphic...windowperf.jpg
And I've seen a post with a perf white top with solid stripes.
Old Feb 20, 2008 | 02:46 PM
giantjoe's Avatar
giantjoe
I decided to go with the white perf. It was definitely the better choice. I love it. You can barely see the stripes through the graphic. Sometimes not at all.
Old Feb 20, 2008 | 03:22 PM
drewster's Avatar
drewster
giantjoe, i like the stripes
which vendor did they come from?
Old Feb 20, 2008 | 03:32 PM
giantjoe's Avatar
giantjoe
well... The "sport stripes" came from my dealership on delivery, but the perforated sunroof graphic came from a sign shop that I worked at during the summer. I custom measured, chose the colour and installed myself (with help from friends at the sign shop). It took about 3/4 hour to peel the old sport stripes off and put the perforated vinyl down. Retail cost for the job would have been around $400 but I got the "Joe discount".
Old Feb 20, 2008 | 03:49 PM
CR&PW&JB's Avatar
CR&PW&JB
As it was explained to me when I got my roof graphic, the perforated vinyl has about half the lifespan of full vinyl. And it does required some specific care to help its lifespan.
Just keep that in mind when making the decision on which vinyl product is best for you.
Old Feb 20, 2008 | 09:14 PM
giantjoe's Avatar
giantjoe
Yep perf only is warranted for 1 year even if overlaminated, but if you have a mostly white roof graphic it won't really be prone to fading...
Old Feb 21, 2008 | 07:06 AM
giantjoe's Avatar
giantjoe
I took a picture with my cell today showing the inside of the perf sheet. It really just looks like it's tinted.
Attached Thumbnails Sunroof Graphic - White/Clear Squares?-2.jpg
Old Mar 30, 2008 | 05:23 AM
Hubs's Avatar
Hubs
Hi are the graphics on a sunroof installed on the inside or outside?
thanks
Old Mar 30, 2008 | 05:37 AM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
thanks
On the outside; that's why everyone mentions taking extra care when washing the car.
Old Mar 30, 2008 | 07:06 AM
CLAG's Avatar
CLAG
very nice job giantjoe
Old Apr 13, 2008 | 04:55 PM
Dory the Cooper's Avatar
Dory the Cooper
hey joe want to come to california and do that to me car! That is EXACTLY what i want to do to it!!!
Old Apr 13, 2008 | 08:59 PM
giantjoe's Avatar
giantjoe
You pay for the ticket and I'll be there. Thanks for everyone for the compliments. I absolutely love it as well.
Old Apr 13, 2008 | 09:20 PM
Dory the Cooper
I could by a ticket but with all these airline companies going out of business I dont know you would make it.
ian260
Mar 29, 2017 06:08 AM
Jim Ferrell
Oct 6, 2015 08:09 AM
Sep 29, 2015 03:36 PM
Sep 28, 2015 09:13 AM
Sep 25, 2015 12:32 PM
