Interior/Exterior Billet aluminum supercharger grille!
Old Nov 25, 2007 | 02:38 PM
ImagoX's Avatar
ImagoX
So...
I'm in Macy's this weekend, one that's closing up. They're selling the fixtures, the shelves, the dummies... everything. And what do I spy but 4 shelves, made of heavy (1/8") perforated aluminum?
So, of course, I buy them:
I run home and break out my Dremel and cutting wheels, pull on some eye protection and get busy... A while later, I have... This!
I dropped the result into my supercharger scoop opening, replacing the black hex-shaped plastic insert I had from my last car.
I think it came out rather well, personally. Plus, it's so strong, I bet it could deflect a crow, let alone bugs...
Old Nov 25, 2007 | 03:03 PM
CooperGear's Avatar
CooperGear
From: Greater Chicagoland. Ich Bin Ein Midwesterner!!!
Looks great! Love the contrast.
Old Nov 25, 2007 | 03:09 PM
markldriskill's Avatar
markldriskill
very nice!!
Old Nov 25, 2007 | 03:15 PM
ACEkraut11's Avatar
ACEkraut11
So, what are you doing with the rest of them? Care to sell one?
Old Nov 25, 2007 | 03:25 PM
ImagoX's Avatar
ImagoX
Funny you should mention that...
And I'm really liking the aluminum color as well - it picks up the chrome headlight ring accent wonderfully.
Old Nov 25, 2007 | 03:37 PM
ACEkraut11's Avatar
ACEkraut11
I assume you might be interested in selling them then. If so, what are the dimensions? Second, can I be first in line?
Old Nov 25, 2007 | 03:40 PM
ImagoX's Avatar
ImagoX
Sent you a message. I made THESE a while back out of black plastic material so I have the perfect template... They just drop into the supercharger scoop. These will fit 2002-2006 (plus the 2007 cabrio). I can do the 2007+ turbocharged coupe if someone in Ohio can let me make a template out of their 2007 insert.
Old Nov 25, 2007 | 04:09 PM
MUShadd's Avatar
MUShadd
ok...since when did your car turn purple. i must have missed that thread..
Old Nov 25, 2007 | 04:10 PM
Crashton's Avatar
Crashton
When can we meet you new manikin friend? Not very nice to call her a dummie.
Old Nov 25, 2007 | 04:13 PM
ImagoX's Avatar
ImagoX
Oh, a while back...
Old Nov 25, 2007 | 04:16 PM
minimarks's Avatar
minimarks
Good job, looks great! Please give me a PM as I would be interested in one.
Old Nov 25, 2007 | 04:30 PM
ImagoX's Avatar
ImagoX
Thanks for saying so. I think they turned out well... I've been looking for material like this in the proper thickness forever, but everywhere else I looked wanted to sell me huge sheets intended for building purposes for lots and lots of $$$. I knew that patience would pay off eventually.
Old Nov 25, 2007 | 05:32 PM
jw34's Avatar
jw34
This looks really nice. And I'm jealous of anyone finding cool metal scraps! So do you expect this will darken when it's exposed to heat? I wonder if the heat will cause it to darken kinda splotchy.
Old Nov 25, 2007 | 05:41 PM
PGT's Avatar
PGT
those shelves would be perfect for people trying to build a false floor in the trunk. I'd love one myself...I could mount the amps and subs under there and they'd be able to breathe and I'd could toss junk in the back with no fear of ruining anything.
Old Nov 25, 2007 | 05:45 PM
jimz68's Avatar
jimz68
Nice!!
I'd be interested in procuring one,too.
Jim
Old Nov 25, 2007 | 05:49 PM
ImagoX's Avatar
ImagoX
Well, the cut-off wheel got REALLY hot, and it didn't discolor on the area of the cut, so short of an engine fire, I think you'll be OK.
I wish they were scraps - alas, I had to buy an entire Department Store clothing display for just the shelves... But given the quotes I was getting for the acres of material I had to get from building supply companies, it was still something of a bargain (I guess). I'll probably cut up half of them, see if people like these grilles as much as the plastic ones I was using before, and save the rest for "special projects" like the boot floor (yes, it would work great for that application, given its thickness).
COOP310's Avatar
COOP310
I like the new car... any lighting yet?
Old Nov 25, 2007 | 05:56 PM
ImagoX's Avatar
ImagoX
No lighting MODs yet (sigh)... Procuring parts ATM. Soooooon....
Old Nov 25, 2007 | 06:17 PM
ScottRiqui's Avatar
ScottRiqui
Looks beautiful - very nice work!
One question, though - how is it "billet aluminum"? Looks like (thick) perforated aluminum sheet metal.
Old Nov 25, 2007 | 06:48 PM
ImagoX's Avatar
ImagoX
LOL... It is, but it has that "billet" look. It IS solid metal though (very solid).
Old Nov 25, 2007 | 08:34 PM
blackie's Avatar
blackie
+1 How much? Although I have a bigger scoop to cover (I have both the PU and M7 CF scoops).
Old Nov 25, 2007 | 08:54 PM
ImagoX's Avatar
ImagoX
Well, MY grille is also designed by a world famous artist (me), so they'd compliment each other, I'm sure.
I can make one custom for your PU or M7 scoops, I bet - can you trace the opening on paper and send it to me? Be sure to use the OUTER edge of the scoop (so some additional material is sandwiched between the liner and the bonnet metal) and I'll use your template for the cut-out instead of mine. LMK if you want to give it a whirl.
Old Nov 25, 2007 | 08:57 PM
ACEkraut11's Avatar
ACEkraut11
Well, the cut-off wheel got REALLY hot...
Have you thought about using a metal cutting saw blade and a saber saw?
Old Nov 25, 2007 | 09:00 PM
ImagoX's Avatar
ImagoX
Yes actually... I'm not sure of that will work or not. The aluminum is quite stout, and I was worried that the hole pattern would catch the blade and just snap it off. I imagine such a saw blade isn't cheap and if I snapped it after 15 seconds I'd be royally PO'd. At last cutting wheels are relatively easy to replace and not too expensive... We'll see how many I chew through making these things, though...
Old Nov 25, 2007 | 09:13 PM
ACEkraut11's Avatar
ACEkraut11
It will work quite well, just take it slow. Even thick aluminum is soft and the blades really arent that expensive.
