Interior/Exterior Billet aluminum supercharger grille!
No worries with the metal-cutting blade. Like ACE said, just go slow. Also, avoid putting *any* lateral pressure on the blade. I've done a lot of glass cutting using diamond-coated ring saw blades that are about $75 each, and the only times I've had problems are when I've tried to go too fast, or pressed the piece I'm working with from the side, instead of straight into the blade.
Well, MY grille is also designed by a world famous artist (me), so they'd compliment each other, I'm sure.
I can make one custom for your PU or M7 scoops, I bet - can you trace the opening on paper and send it to me? Be sure to use the OUTER edge of the scoop (so some additional material is sandwiched between the liner and the bonnet metal) and I'll use your template for the cut-out instead of mine. LMK if you want to give it a whirl.
PM me if you want to try a custom-made one (assuming you can send me a tracing template and the aftermarket scoop insert looks like it will properly sandwitch the insert). I don't see why it would be any more work than making one from MY template - I mean, it has to be roughly the same size since it still has to fit inside the bonnet aperture, right?
The fact that you are having a hard time cutting it with a cut off wheel tells me it's most likely not aluminum. I have some experience cutting stainless & it's a bugger to do.
Well, I found some very pricey but very tough cutting discs at Anderson's tonight - I still can't make an entire cutout with a single disc though... Maybe Chuck is right and it's stianless after all. Plus, I've cut up a bunch of aluminum PC cases for MODs, but I don't remember aluminum sparking like this when I cut on it:
Either way, these are some serious guards... Literally stronger than the bonnet material around them. In the even of a nuclear war, they'll be nothing left but roaches and these grilles, glowing softly in the irradiated night...
I was going to ask you if the material was sparking as you cut it. I agree, that doesn't look like aluminum from the sparks you're getting.
(I remember one of my old textbooks actually showed what the grinding sparks look like for various metals, but I'll be darned if I can find it now.)
EDIT - Found it - it's called "Spark Testing", and the sparks you're getting seem to be consistent with stainless steel.
Thanks for the link!! I agree - the sparks are consistent with stainless - straight, white-tipped, no sparklers and the ends fork.EDIT: Duuur. Badge magnets stick to it... Definitely not aluminum. I'm such a dork.
If they stick fairly well, the shelving is probably 400-series stainless, which would make sense. If the magnets barely stick, it might be 300-series that's become slightly ferromagnetic through cold-working, but 300-series is usually used for things like high-quality knives and pieces where cosmetic appearance is very important.
Since your material started off life as shelving, you've probably got 400-series stainless steel, which is a really nice material for what you're making.
looks good. The mesh looks a bit thick for me with regards to airflow. this store has over sized cutting wheels and the original "modders mesh" that has the honeycomb mesh.
http://www.mnpctech.com/casemodstore.html
That looks pretty sly! I'd be interested in one for my ensuing R56 MCS if you've found someone willing to let you use their insert as a template. I'd offer up mine, but right now it's lost somewhere in the middle of the Bermuda Triangle.
Making the shape isn't the issue - what I need to see is if there's a way to "sandwich" the grille betweer the metal of the bonnet and the insert (as in the R53) or if I'll need to make allowances for additional fasteners.
I'll keep an eye on this thread and hopefully someone will graciously offer up their R56 as a test subject.
looks good.
This being NAM (where one is always called out for making statements) - I gonna have to call you out on this "stop a crow comment"
- either buck up the evidence (pics, please
) or retract
) or retract
) or retract
) or retract
