Interior/Exterior Smoothing and powdercoating IC Horns and IM
Old Nov 20, 2007 | 03:23 PM
1nf3rn0's Avatar
1nf3rn0
A little project I've been working on recently was smoothing out the ugly ridges on my IC horns. Heres what it looked like half way:
Last night, I finished smoothing them, and sent the horms and my intake manifold off to my powdercoater to get a nice glossy red coat on them. I should get them back next week and I will post pics.
Old Nov 20, 2007 | 04:25 PM
skillet's Avatar
skillet
Who's doing your powdercoating, and if I may ask, how much?
Look forward to finished pictures.
Thanks!
Old Nov 20, 2007 | 06:02 PM
1nf3rn0's Avatar
1nf3rn0
Cramer Tech Coating in Ann Arbor, MI. Its going to be around $200 because of all the masking they have to do... if I didn;t have to worry about getting the coating inside the parts, it would have been less than $50....
I'm thinking of offering this service (smoothing and coating) but it wont be cheep. Its close to 8 hours of labor....
Thanks!
Old Nov 20, 2007 | 06:16 PM
NJDM's Avatar
NJDM
i cant see pics.....idk if im the only one
Old Nov 20, 2007 | 06:25 PM
Call's Avatar
Call
I sort of like the ridges
Old Nov 20, 2007 | 06:27 PM
NJDM's Avatar
NJDM
wait now the pics work.....i to like the ridges better, but nice work on em
Old Nov 20, 2007 | 06:29 PM
twin scroll's Avatar
twin scroll
Call is that candy apple red paint or powdercoat?
Old Nov 20, 2007 | 06:34 PM
1nf3rn0's Avatar
1nf3rn0
I like it better w/o them... Not like it will matter much soon though, as I'm getting the Rotex and doing a FMIC....
Old Nov 20, 2007 | 06:53 PM
PGT's Avatar
PGT
the ridges are there for ridgity. I wonder how smoothing them affects integrity of the piece. I know that's a ton of work....it took me a few hours to smooth out the 'Alta' logo on the 1st gen TMIC and prep it for paint.
Old Nov 20, 2007 | 07:26 PM
1nf3rn0's Avatar
1nf3rn0
And I had to do the entire thing with a hand file because of the wonderful low melting properties of aluminum
The integrity should be fine.... The material is still quite thick. If it isn't, only the passenger side horn would fail... Not too bad a mistake...
Old Nov 20, 2007 | 07:33 PM
PGT's Avatar
PGT
I used a small rotary detail sander with 60 grit, always at low speed. Hand files as well. I respect the amount of work needed to get those horns looking like that. I had a spare pair and painted them red.....quite a bit of work taping them off to preserve the mounting surfaces.
Old Nov 20, 2007 | 09:02 PM
1nf3rn0's Avatar
1nf3rn0
Thus the high cost from my powdercoater... Its alot of work bur the end result is worth it to me....
Old Nov 21, 2007 | 04:06 AM
Call's Avatar
Call
Powder coating.
Old Nov 21, 2007 | 05:56 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Looking good. I'm more into function with my mods though.
I was all concerned when my Aeroquip hose started to wear into the IC horn. Now I can see there is no cause for alarm because there is more than enough material for it to eat into untill I get poly engine mounts.
Old Nov 21, 2007 | 06:42 AM
CHKMINI's Avatar
CHKMINI
The ridges assist in heat dispensation as does the bare metal finish.
Old Nov 21, 2007 | 06:55 AM
checkers's Avatar
checkers
That's a great price on the powder coating!! Mine going to cost $450 for the same parts. I guess thats the difference between MICH. and CALIF.
Old Nov 21, 2007 | 07:01 AM
1nf3rn0's Avatar
1nf3rn0
I'm sure the difference was mostly because of the black chrome.
Old Nov 22, 2007 | 12:46 PM
checkers's Avatar
checkers
here's what black chome looks like
Old Nov 22, 2007 | 12:52 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
There aren't nearly enough ridges to increase the surface area to enhance cooling that much. The ridges aren't very high and spaced pretty far apart....i bet you lose very little surface by shaving them down...
Old Nov 22, 2007 | 01:35 PM
checkers's Avatar
checkers
I'll have more later when they get installed.
Old Nov 22, 2007 | 01:42 PM
earlrabbit's Avatar
earlrabbit
How hard is it to remove the air horns?
Pker
Apr 11, 2017 12:14 AM
gnhovis
Dec 14, 2015 05:31 PM
martinb
Oct 7, 2015 05:00 PM
Emnotek
Sep 29, 2015 07:37 AM
