Interior/Exterior harness install
Old Oct 25, 2007 | 06:52 AM
Chase's Avatar
Chase
harness install
Does anyone have any pics of a 6 point harness install. I know what it looks like finished, i just need some pics during, like with the seat out, so i can see where i need to drill for my eye hooks for the lap belts. Also, i talked with Peter at m7 about this, but i just wanna see if anyone else has anything to add. Im trying to figure out how to hook up my submarine (crotch) belts. I know that you can hook them to the mounts if you have a bottom mount seat, but i have a side mount. So do i just drill though the floor? If so, That means that will change the position of them everytime i adjust the seat, so they wont be directly under my shoulders, etc... Anyway, let me know anything. Thanks
Old Oct 25, 2007 | 07:43 AM
onasled's Avatar
onasled
Chace,
Sub belts should attach to the same point as your lap belt.
Inside eye you just need to drill a hole in the exhaust tunnel as close to the floor as you can get. You can then pry away the exhaust shield from under the car and get you hand up there to put on a LARGE washer and bolt with lock washer. Easier if you have help.
The outside eye should also go as low as possible. I think the best thing here would be to remove your rocker panel cover. You will then find two large oval openings covered by rubber grommets. Remove the rear one and that will give you access to the inside of that rocker panel. Then you can figure out just where to drill that hole. You will see why I say go as low as you can as the rocker is double walled near the top.
The floors of the Mini are VERY thin so I would NOT attach anything there.
As far as how far back to go, the lap belt should be more upright then angled back, so.... the attachment point should not be too far back from where your belt exits the seat on the side.
Old Oct 25, 2007 | 07:50 AM
Chase's Avatar
Chase
OK that is some good info. Do you have any pics at all i could look at? That would help me out alot.
Old Oct 25, 2007 | 08:06 AM
onasled's Avatar
onasled
No, don't think I do Chace. Also just thought that you most likely won't be able to get your crotch harness over to the lapbelt pickup points with the side mount plates in the way. Hmmmm, have to think about that one.
Old Oct 25, 2007 | 08:24 AM
ScottinBend's Avatar
ScottinBend
What seats and mounts are you using?
Old Oct 25, 2007 | 12:12 PM
Chase's Avatar
Chase
Im using sparco evo seat and the Brey Krause mounts
Old Oct 25, 2007 | 12:13 PM
Chase's Avatar
Chase
yeah thats what i was wondering. Let me know if you think of anything
Old Oct 26, 2007 | 08:48 AM
Chase's Avatar
Chase
bump
Old Oct 29, 2007 | 10:04 PM
Chase's Avatar
Chase
From the info i gathered from your pm on mu, i think that if i mount the sub belts to the bottom of the sliders, it will raise the seat hieght too much. Even though its only an 1/8 - 1/4 of an inch, it makes a difference. I dont know. Ill keep fiddling
Old Oct 29, 2007 | 10:18 PM
gnatster's Avatar
gnatster
My sub belts are bolted through the floor. Welded 4x6" plates that have nuts welded to them on both sides. Used an eye bolt and licktite red. belts have snap on hardware. It's probably overkill but one can't be too safe.
Old Jul 13, 2008 | 01:09 PM
freeskier's Avatar
freeskier
sorry to bump a dead thred but im using the same setup as the OP and was looking for some pictures. thanks
Old Jul 13, 2008 | 10:54 PM
ScottinBend
Are you using a race seat?
Old Jul 14, 2008 | 01:39 PM
freeskier's Avatar
freeskier
sparco evo on brey krause mounts to factory sliders.
adrchn
Aug 13, 2019 02:11 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
squawSkiBum
Oct 2, 2015 09:21 AM
Super Coop
Aug 17, 2015 05:09 PM
