Interior/Exterior R56 4-point harness (like Schroth)
Old Apr 11, 2012 | 06:02 PM
  #101
dboard7's Avatar
dboard7
Originally Posted by 07chilired
The schroth harness will fit in the R56 with some slight modifications. I have one in my R56. All you have to do is shave some of the black plastic off of the piece that goes into the driver side buckle. It does not hurt the harness structure at all.
I just picked one up from a fellow mini owner dirt cheap! I cut of the little bit of plastic and it works great! i did notice one thing though, where the harness goes through the head rest after i used it i noticed that the harness pulls down on the leather and pulls it away from the plastic, does this happen to you?
Old Jun 11, 2012 | 09:38 PM
  #102
89AKurt's Avatar
89AKurt
About time!!!!!!!!
Schroth Harnesses IN STOCK at WMW
Old Jun 12, 2012 | 11:51 AM
  #103
WayMotorWorks's Avatar
WayMotorWorks
Vendor
FYI, I just got a batch and test fitted them in my Clubman and no cutting was needed they worked fine.
Old Jun 14, 2012 | 05:51 PM
  #104
89AKurt's Avatar
89AKurt
Cool, that was quick! Got it, and installed.
Old Jun 28, 2012 | 07:48 PM
  #105
peter314's Avatar
peter314
wait wut?...
Way how did you get them? I've been working with HMS the distributor of the belts and they just released them today, Mine were at the house waiting for me when I got home.
Attached Thumbnails R56 4-point harness (like Schroth)-imag2251.jpg   R56 4-point harness (like Schroth)-imag2252.jpg
Old Jun 28, 2012 | 07:51 PM
  #106
WayMotorWorks
Vendor
Originally Posted by peter314
wait wut?...
should have called us, they aren't listed from Schroth that they do, but we tested fitted them and the schroth quickfit harness will fit.
Old Jun 28, 2012 | 08:05 PM
  #107
peter314's Avatar
peter314
What do you mean "That they do"?
Over the last few months that I worked with HMS I learned that they are the North American distributor of Schroth, so if you didn't get them through them then who did you get yours from? direct from Germany?
What took them so long was the legal end, they had belts they just needed certification.
Attached Thumbnails R56 4-point harness (like Schroth)-imag2253.jpg   R56 4-point harness (like Schroth)-imag2254.jpg
Old Jun 29, 2012 | 06:18 PM
  #108
89AKurt's Avatar
89AKurt
... What took them so long was the legal end, they had belts they just needed certification.
I was wondering about this label when I installed my belts! Thanks for bringing this detail up. Here is the label on my belt:
http://www.flickr.com/photos/53074154@N00/7469863740/
My question, what is different between the belts? Is it hardware like bolts and washers? I did find out the star drive size for the rear seatbelt screw is different.
Old Jun 29, 2012 | 10:38 PM
  #109
peter314's Avatar
peter314
Way... I am disappoint
Old Jul 2, 2012 | 09:45 AM
  #110
WayMotorWorks
Vendor
We admit our mistake. The belts are the same the only difference is the label. We will exchange them out no problem for the ones with the correct label.
Old Jul 2, 2012 | 09:51 AM
  #111
89AKurt's Avatar
89AKurt
Thank you.
Old Jul 13, 2012 | 04:17 PM
  #112
89AKurt's Avatar
89AKurt
http://www.flickr.com/photos/53074154@N00/7564773588/
Received the correct seatbelt. Note the serial numbers, but the tag is obviously different. Other than that, no difference! Ain't government red-tape wonderful?
Old Jan 15, 2014 | 10:57 AM
  #113
Bster13's Avatar
Bster13
Has any tech at an HPDE balked at an R53 harness being modded and then used in an R56? There are used R53 Schroth harnesses around I'd like to use in my R56, but it wouldn't be worth much if I went to a trackday and failed tech.
Old Jan 15, 2014 | 11:13 AM
  #114
dboard7's Avatar
dboard7
I had no issues with mine when I ran it. I did about 7 events here in the Midwest and just got completed on how cool it was lol
Old Jan 24, 2014 | 01:56 AM
  #115
Island maser's Avatar
Island maser
I have my R56 4 point harness for sale. I purchased mine from Phil Wicks a famous MINI racer who has them made. I piad $400 for mine and they work great. 2 bolts on the rear of the driver seat and you are good to go. This is drive side only. They clip into the rear seat locks. Never had an issue with Tech. If you are taking an instructor along sometimes they want you to have the same system so I just would use the stock 3 point. Never had it happen. Everyone I have ridden with said no problem lets go.You do wear the standard 3 point harness over the top. That way you get no lights warnings or messages and your airbags all work as designed. These will lock you into your seats. I just sold Black Jack so I have no need for them. Best offer and they are yours. Also have a set of Wheels for sale with Nitto NT 01 mounted up. They have about 3 or 4 more track days left in them. Best offer.
Wohnson89
Jun 10, 2020 04:53 AM
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
Sep 1, 2015 04:02 PM
zre
Sep 1, 2015 07:20 AM
