Interior/Exterior Non-slippy clutch pedal?
Old May 30, 2007 | 02:12 PM
godskid's Avatar
godskid
Hey -- anybody know of a clutch pedal replacement which will help me not slip off the pedal, when it's been raining or snowing out? If I get any water on my shoes (several different pair) I find the clutch pedal very slick. I keep slipping off it. Not fun!
Old May 30, 2007 | 05:55 PM
devious duck's Avatar
devious duck
instead of taking and swapping out pedals, how about see if you can have your oem ones sand blasted or what not. That may take the gloss texture off and leave a more of a matte finish for grip. may or may not work, but thats the route i would take. Most of the aftermarket pedals i have seen for various cars never really look like they belong.
Old May 30, 2007 | 06:19 PM
thlaxx's Avatar
thlaxx
im pretty sure, i havnt looked at my pedals in a while, but there are rubber lines that are a bit less than 1cm high off the pedal which cause it to be very slick when wet, i to have had this problem, but im not in a high rain or snow area so im leaving them, and just being extra careful when it does.
you may want to look into getting some cooper pedals, just the solid black.
Old Dec 4, 2009 | 11:52 AM
Victa's Avatar
Victa
i was going to post something about this today.
i agree with the original poster, i have been looking for aftermarket pedals and i see that ultimatepedals are the way to go as far as the best bang for your buck. my question is whether i shoudl go for the ones with the rubber nubs or just the textured billet... does anyone have any experience with using both?
Old Dec 4, 2009 | 11:53 AM
Victa's Avatar
Victa
to my previous post. what i mean is, will the rubber nubs basically do the same squeeking/slipping in wet conditions? basically what are the pros/cons between the two. thanks in advance.
Old Dec 5, 2009 | 01:00 AM
eg0911's Avatar
eg0911
a cheap solution that i would use, you can remove the rubber parts and put on like skateboard grip tape. we use skateboard grip tape on a few of our racecars and it works great. its not a very factory look or anything but it will solve your issue for less than $8
Old Dec 12, 2009 | 09:15 PM
carsncars's Avatar
carsncars
I noticed the slippery/squeakiness in the rain, too, though I just had to be more careful. +1 on skateboard grip tape (it's sort of like the grip tape they use on metal stairs).
Old Dec 13, 2009 | 05:41 AM
Flyinace2000's Avatar
Flyinace2000
Thats a great DIY solution!
Old Dec 13, 2009 | 06:15 AM
slinger688's Avatar
slinger688
Is the skateboard grip tape the same as the 3M anti slip tape you get from the DIY stores or is it better?
Old Dec 13, 2009 | 06:52 AM
Gilboyto's Avatar
Gilboyto
griptape for a skateboard is basically a large sheet of sandpaper with adhesive backing. There are different grits that you can buy for skateboards depending on your style...so it just depends on your liking .
I chose the fine grit stuff so I dont stick to my board as easily.
http://www.amazon.com/Mob-Skateboard.../dp/B002E0B2BK
Its very cheap too for a fairly large sheet
Old Dec 13, 2009 | 03:50 PM
Flyinace2000
Can you post a picture of your pedals. I can't imagine i would look to bad.
Old Dec 13, 2009 | 04:02 PM
J_'09s's Avatar
J_'09s
I've always slipped my foot back and forth to press and release the clutch. I don't really keep my foot planted in any certain position. I guess i'm different than everyone else.
Old Dec 13, 2009 | 04:47 PM
Gluhwein's Avatar
Gluhwein
Cheaper to buy different shoes.
Old Dec 13, 2009 | 05:37 PM
drewstermalloy's Avatar
drewstermalloy
Really good idea. I've been slipping off my clutch all week!
Old Dec 16, 2009 | 07:07 AM
callahan00's Avatar
callahan00
Follow the link below. i have these on my '08 R56. They look great and they are very secure. Instead of rubber inserts, they have set screws that provide the grip. Note, they are technically for gen 1 but they fit on Gen 2 just fine.
http://voltageproductsonline.com/pedals.html
Old Dec 16, 2009 | 08:43 AM
Victa's Avatar
Victa
after a week of rain and a week of applying the jessup grip tape ($2 for 1 ft at a local skate shop) i found that at first the grip tape was a little toooo grippy. but i quickly wore it down a little and it feels awesome. no annoying squeekie noise. i figure ill be using this for the time being until i do more research and save more money on getting a set of nice pedals. thanks for the recommendation above callahan00
Old Dec 16, 2009 | 12:58 PM
Victa's Avatar
Victa
i have a feeling the screws would be a bit too much traction. The pedals on the mini have a pivot point from the top rather than from the bottom so when i shift i actualy have a sliding motion (down the face of the clutch pedal) when pressing/depressing the clutch. If its too grippy it doesnt allow me to shift smoothly. is this an issue for you callahan00? ***hope you were able to follow my description
Old Dec 16, 2009 | 01:08 PM
callahan00's Avatar
callahan00
That is the nice thing about these pedal covers. You can adjust the height of the screws to where you want them so the grip can be as little or as much as you like.
So for instance, if you want the brake pedal to grip your foot tightly but want some slide on the clutch, simply adjust the screws.
Plus they really look great.
drrigg
May 27, 2022 03:31 AM
scfiveo
Sep 27, 2019 02:27 PM
eliseo1981
Nov 2, 2015 11:24 AM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
