Upper Engine Mount Failed Again? CPO Warranty Ending
Old Feb 23, 2026 | 11:23 AM
chefjoseph's Avatar
chefjoseph
In July 2025. After many calls to MINI USA (who refused to replace it under the CPO Warranty at 38,00 miles) and haggling with my dealer, they performed a "Goodwill" replacement of the mount. Of course, it's a known issue and there should have been a recall and/or lawsuit to force a recall. Now, 7 months later, I notice that about 50% of the time, the engine "shudders" a bit on shutdown. I am also having an intermittent issue (more noticeable when its very cold, where I hear what sounds like the front flaps are scraping against something when driving over dips in the road coming from the front passenger side. NEITHER of these issues are covered under the completely inadequate extended CPO Warranty, which ends in April 2026. I am bring the car in for a final checkup on 3/9. Is it possible that in 7 months that the mount could have failed AGAIN? I am also getting this message on my AutoPhix OBD 2:
Thanks, Joseph
Old Feb 28, 2026 | 12:56 PM
chefjoseph's Avatar
chefjoseph
Does no one interact with posts anymore?
🤷🤷 I'm overwhelmed by the response.
Thanks, Joseph
Old Mar 2, 2026 | 04:54 PM
michaelo's Avatar
michaelo
A motor mount should last at least 40,000 miles in general, so I do not think that is the problem. As for that code, you might have a weak battery. Have the checked out first.
Old Mar 7, 2026 | 10:11 AM
chefjoseph's Avatar
chefjoseph
Upper Engine Mount
40,000 miles for an upper engine mount which costs nearly $2000 to replace??
Sorry, but that's unacceptable. I've never had these issues with any other car, even the six BMW's I owned over the years.
Old Mar 7, 2026 | 01:56 PM
michaelo's Avatar
michaelo
I said 'at least 40,000' that means the minimum....it could go for 100,000
Old Mar 8, 2026 | 05:04 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I agree that $2000 to replace a motor mount is excessive. There are options. I’ve seen at least a few different video tutorials on how to replace the mount yourself. If you are even slightly handy in the garage, it’s not too difficult to replace yourself, and the GP3 version seems to be built a little better. If your warranty won’t cover the replacement, start surfing YouTube to learn how to do it yourself. I find wrenching on cars rewarding when you can tackle an expensive repair on your own.
Old Mar 13, 2026 | 07:49 AM
Hello,
Yep, all the DIYs are here and options: https://www.northamericanmotoring.co...rchid=21368206
https://www.reddit.com/r/AskAMechani..._a_code_u0100/
Check the ground strap: https://www.minif56.com/threads/f56-...ocation.95368/
https://www.realoem.com/bmw/enUS/sho...diagId=12_2658
https://www.ecstuning.com/b-genuine-...e/12428602991/
Or
https://www.ecstuning.com/Search/Sit...h/12428741637/
chefjoseph
Jun 12, 2021 02:18 PM
peanut_man
Aug 16, 2010 06:45 AM
coopster
Jun 6, 2009 07:51 PM
Poppa Bear
May 20, 2008 03:27 PM
meb
Oct 6, 2006 04:02 AM
