R53 clutch alignment tool
Old Apr 29, 2023 | 06:44 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Does anyone have one I can use for a couple days. I’m in Panama City beach Florida. Would like to rent it.
Old Apr 29, 2023 | 07:49 PM
cooper48's Avatar
cooper48
Won't do you much good because there's no pilot bearing to align.
Old Apr 29, 2023 | 09:05 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Mini makes on specific for the r53 to align the clutch.
Old May 12, 2023 | 03:28 AM
ArthurMcKinney's Avatar
ArthurMcKinney
Thanks for the info, I didn't know that.
Spoiler
Old May 12, 2023 | 06:11 AM
Xplct's Avatar
Xplct
Yeah pretty much have to feel for center while tightening the pressure plate I used the cheap plastic alignment tool my kit came with to help move it around.
Old May 12, 2023 | 08:05 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
I have one that I'd be glad to let you borrow if you just cover USPS mailing cost.
Can confirm that it was quite handy 'n helpful when I did my clutch, but that was the first and only R53 clutch I've done so have no idea how it'd be without the tool.
Old May 15, 2023 | 01:10 AM
glark's Avatar
glark
I needed this tool for a 2009 Cooper Clubman S. Couldn’t find anywhere until I came upon this seller. You sir are a lifesaver!
Tutuapp 9Apps Showbox
Old May 15, 2023 | 05:41 AM
Xplct's Avatar
Xplct
It’s not hard, my issue was having some burrs in the female spline of the clutch that I was unaware of until trying to install the gearbox, I’m going to say that before installing the clutch, make sure it slides very easy over the spline on the gearbox before installing! Both directions. I had to take a file and remove the burrs inside the clutch. I believe this is what caused me to destroy my gearbox. The clutch I used was clutchmasters. The cheap plastic alignment tool is not made to the same tolerance as a stock metal spline. I think I’m going to take the stock spline out of my old gearbox and make an alignment tool out of that myself, if I had the time at work I would custom make a bunch of these.
Old May 15, 2023 | 10:32 AM
cooper48's Avatar
cooper48
Sounds like a lucrative side gig for someone with a 3D printer.
njaremka
Sep 26, 2019 02:12 PM
tag1260
Dec 12, 2017 12:42 PM
anyheck
Dec 10, 2013 04:42 PM
Carmichael
Chicago MINI Motoring Club
May 16, 2012 02:52 PM
R35P3CT DA M1N1
Nov 1, 2010 08:21 PM
