Drivetrain Clutch alignment tool?
Old Sep 19, 2019 | 07:05 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Usually when you order a new clutch kit, you get an alignment tool. Not so with Mini
If I purchase an OEM clutch kit, what tool is recommended for centering the friction disc? Or is not having one a non-issue?
Old Sep 26, 2019 | 01:54 PM
MiniToBe's Avatar
MiniToBe
I never used such tool. just marry the too and worst case scenario you rotate the engine a bit until it slides in.
Old Sep 26, 2019 | 02:12 PM
cooper48's Avatar
cooper48
+1 on MiniToBe. An alignment tool is not necessary because a MINI has no pilot bearing to align with the clutch disk. Stick a ratchet on the crank bolt and turn it a bit and the input shaft should slide right in.
tag1260
Dec 12, 2017 12:42 PM
Yankee
Aug 5, 2016 02:52 PM
monkeyb0y
Apr 4, 2014 09:25 AM
Carmichael
Chicago MINI Motoring Club
May 16, 2012 02:52 PM
R35P3CT DA M1N1
Nov 1, 2010 08:21 PM
