electrical problems
Old Dec 19, 2019 | 07:36 AM
eric puskar's Avatar
eric puskar
electrical problems
ok I have a 2007 mini S with some electrical problems, first the rear hatch latch keeps popping open for no reason, when you shut the lights off the hatch opens, when you hit the motor stop button the hatch opens. the key fob works and the switch in the hatch itself works. also I found out today that my wipers washers do not work either front or rear doesn't sound like the washer motor is working.
I live in Pennsylvania so it is pretty cold here now, I bought the mini this summer and this is the first electrical problem ive had.
anyone run into anything like this before???
Old Dec 19, 2019 | 09:28 AM
cooper48's Avatar
cooper48
First, remove the battery and have it tested at AutoZone or a similar parts store. It's likely the cold weather is affecting a weak battery and that can create all kinds of electrical gremlins in a MINI. Also, if the battery has been recently replaced, still have it tested. They are sometimes not up to snuff.
Old Dec 19, 2019 | 08:49 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Remember if you replace a battery in a mini You need to reset you alternator. The electrical system in a mini uses a smart charge system. Even if you replace the battery. The car will still think an old battery is still being used.
Old Dec 20, 2019 | 05:22 AM
eric puskar
thanks guys, but how do you reset the alternator?
Old Dec 20, 2019 | 05:32 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
You can get Mini to reset. Or you can get INPA an cable to reset. Got mine from Amazon .
Old Dec 20, 2019 | 05:41 AM
MiniToBe's Avatar
MiniToBe
all of these functions come out of the fuse box. if you have a sunroof, check the fuse box for water damage/corrosion. Also, sometimes the trunk handle cracks/breaks causing water to get in and corrode the circuit board. inspect for damage there, too. I've replaced batteries so many times and never had to "reset" the alternator. the proper term is "register" the battery. not all cars require that!!! only the ones with sensor on the battery.
Old Dec 20, 2019 | 05:49 AM
eric puskar
thanks I will look. I've had a few problems with this go cart. But I love it.
Old Dec 20, 2019 | 05:55 AM
MiniToBe's Avatar
MiniToBe
Yeah i feel you...yesterday was going to take the convertible to work and the starter was frozen lol..i took the other mini instead.
with the sunroof, it is more prone to electrical issues since they leak inside. While you at the fuse box, feel the carpet from the bottom for wetness.
Tsquared
Aug 28, 2017 12:26 PM
YO MUDA
Mar 22, 2015 12:00 PM
kg4fxg
Off-Topic :: Autos
Mar 4, 2014 02:17 PM
juanpablo2002
20
Feb 19, 2014 08:28 PM
R53 Speed
Apr 28, 2011 12:16 PM
