Scanguage 2 and clearing codes
Old Dec 21, 2019 | 07:45 AM
Jason Cornelius's Avatar
Jason Cornelius
So I got my scanguage 2 and I’m throwing a p0420 code that clears itself a couple of days after fill up. Doesn’t effect performance at all but I want to clear code via the scanguage. I have tried but get no response from the scanguage and I have swapped the troubleshooting setting in the advanced setup menu with same results. Are we not able to clear the codes?
Old Dec 21, 2019 | 10:30 AM
Blue R50's Avatar
Blue R50
You didn't mention the model you have, but here is how I do it on my 2005 R50 with my generic code reader. I turn the car on but do not start it. Next I plug in the code reader and read the codes. Finally I clear them. If the engine is running they will not clear without BMW's scanner. Hope this helps!
BTW, the P0420 code is indicating poor catalyst efficiency Either you have a bad post cat O2 sensor or a bad cat, and the code will not go away permanently until you fix the issue. If it's a bad cat and it has no impact damage, then something made it fail. This can be either an improper air/fuel ratio or the engine may be burning oil. It is extremely rare to have a catalytic converter be the primary failure.
mgrant
Apr 19, 2013 09:53 PM
curtw
Feb 23, 2012 02:49 PM
Freddie
Oct 4, 2010 05:46 AM
SteveS
Apr 27, 2010 03:22 AM
JCampos
Mar 30, 2009 02:26 PM
