mini cooper lighting control malfunction when engine is running
Old May 16, 2019 | 11:54 AM
Chris Gan's Avatar
Chris Gan
Hello Mini Gurus:
I just purchased a 2013 cooper R56 Baker Street Edition but the lighting control does not work properly.
o When power on & engine off, the lighting control on left side of steering wheel column works properly. Light changes as I switch from AUTO, OFF, PARKING LIGHT, AND LOW BEAM.
o When engine is running. Low beam/DRL (can’t tell difference) and side marker/parking lights are on ALL THE TIME, DAY OR NIGHT. No matter how I play the switch, it wont go off. Anyone have an idea on how to fix this?
o I can’t tell the difference between the DRL and Low beam, is there a difference?
Any input is appreciated!
Chris
Old May 16, 2019 | 12:44 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Is the car battery the original? If so it could be going bad. These cars do strange things when the battery is failing. Could be other things but that would be my first diagnostic step. Many auto supply shops will test battery for you.
Old May 16, 2019 | 12:51 PM
Chris Gan's Avatar
Chris Gan
Thanks for the response. However, I think it should behave normally when the engine is running - because the electrical power is supplied by alternater by then I believe.
Old May 16, 2019 | 01:10 PM
MiniToBe's Avatar
MiniToBe
go through the setting menu. maybe the lights are set to on all the time.
Minnie.the.Moocher
You would think that is correct, but it isn't always the case. The alternator charges the battery, so the alternator could be bad, the battery could also be bad and not allowing the correct power to the devices in the car.
My other MINI would not power any devices through the 12v outlets, even with the car running. After changing the battery everything worked again.
As I said, could be something else entirely.
Old May 16, 2019 | 01:29 PM
Chris Gan's Avatar
Chris Gan
Thank you for the reply. I tried that, no luck,
Old May 16, 2019 | 01:30 PM
MiniToBe's Avatar
MiniToBe
do your widows work ?
Old May 16, 2019 | 01:31 PM
Chris Gan's Avatar
Chris Gan
I see. will check the battery for sure. This is just so wired that it works when power is on and stopped working when the engine is on.
Old May 16, 2019 | 02:03 PM
Chris Gan's Avatar
Chris Gan
Yes, they do, including moon roof.
Even the light control level works fine when power on and engine off.
However, the control level stops working when the engine is on... No matter what I do, headlamp and side markers are on all the time.
hotrods70
Mar 27, 2019 05:36 AM
Beau B
R60/R61 Stock Problems/Issues
Dec 4, 2015 01:12 AM
Julzie
Feb 16, 2014 06:44 AM
mini4door
Jan 28, 2013 06:15 AM
Nedbun
Sep 5, 2011 07:44 AM
