MINI Competition package 2019 WTF?
Old Dec 7, 2018 | 06:25 PM
californiadreaming's Avatar
californiadreaming
I came across this video on youtube. He stated that it has pro suspension added from the dealer. It's a JCW he explains. My question is this... if I just bought a 2019 JCW doesn't it have pro suspension?
Old Dec 9, 2018 | 06:33 AM
peterpan101's Avatar
peterpan101
No, that is an upgrade just like the JCW pro exhaust. This is a coil over set up.
Old Dec 9, 2018 | 09:26 AM
californiadreaming
Coil over setup? What does it do lower your car or something like that? Or what makes it better than the standard JCW?
Old Dec 9, 2018 | 09:50 AM
peterpan101
It's height adjustable. It is a better set up than stock, but unless your serious I feel stock is good enough for most
Old Dec 9, 2018 | 11:49 AM
bratling's Avatar
bratling
Super Moderator
Adjustable ride height. I put the JCW Pro kit on my F55 S. In warm weather I run about 2” lower than stock in the front and 1.5” rear; in the winter I go back to full height for better snow clearance. 😊
Old Dec 9, 2018 | 02:36 PM
mountainhorse's Avatar
mountainhorse
Is this a true height adjustable suspension ... or simply coilovers with preload adjustment??
Any pics or other info on these shocks?
Old Dec 9, 2018 | 02:51 PM
peterpan101
https://www.shopminiusa.com/PRODUCT/...SPORT-CHASSIS/
Old Dec 9, 2018 | 04:49 PM
californiadreaming
Thanks everyone for the help. That makes sense but it's not for me. I'm good to go with my JCW. I actually like the height I have and I'm running 17s.
Old Dec 9, 2018 | 05:23 PM
mountainhorse
Pre-Load and ride height not the same thing.
I thought it might be preload-only adjustable.... which will actually raise/lower the car...but will also change change the spring forces on the car which limits the ability to find the sweet spot at different ride heights.
For that kind of money... there are plenty of shock choices out there that have compression and rebound damping and independent ride-height-adjustment separate from spring pre-load.
Old Dec 9, 2018 | 06:57 PM
dpcompt's Avatar
dpcompt
Adj ride height
Originally Posted by bratling;4436474[left
When you realign the ride height, do you have to have the suspension aligned?
Adjustable ride height. I put the JCW Pro kit on my F55 S. In warm weather I run about 2” lower than stock in the front and 1.5” rear; in the winter I go back to full height for better snow clearance. 😊[/left]
When you change the ride height, do you have to have the suspension realigned?
Old Dec 9, 2018 | 08:27 PM
mountainhorse
If you change ride height, you will change camber...all other things equal.
Lowering the car will move you towards negative camber.
If you are a suspension guru... and know your stuff..or trust in an already "calibrated" setup... then you will know if that change is beneficial to you or not.
Your tires will wear more the further you get away from either extreme.
my 2¢
Old Dec 9, 2018 | 09:11 PM
dpcompt's Avatar
dpcompt
I have about 2200 miles on my '19 JCW Hardtop. It has the standard "sports" suspension. The more I read about these different suspension options and their cost for installation and parts, I think that I will just stay with my current setup. I like the ride and I like the handling, especially for a daily driver.
Old Dec 11, 2018 | 06:14 PM
californiadreaming
I agree with dpcompt - I'm keeping mine just like it is. I love the height and how things. I'd rather spend the cash on Horse Power or another mod for the future. I've had mine less than 3 weeks. Loving every minute of it! JCW ride baby ride!!!
koenner1
Suspension
Dec 8, 2005 09:22 AM
ScuderiaMini
Off-Topic :: Autos
12
Oct 3, 2005 11:19 AM
