JCW Steering Wheel - Installation Issue
Old Apr 3, 2015 | 01:39 PM
JASMCS's Avatar
JASMCS
Hi All,
I just had a local indy MINI shop perform the swap to install the JCW Leather/Alcantara wheel on my R53. What an amazing feeling!
Unfortunately, I noticed on the drive home that the steering wheel is not completely straight. It's off by a few degrees - nothing major, but still enough to be highly irritating.
Is there an easy way to get this fixed, or does the wheel have to come off and the installation re-done? I worry that they'll have to remove the wheel, and pierce the pin hole in the process. Would an alignment take care of this, or would that worsen the issue?
Thanks in advance!
Old Apr 3, 2015 | 01:48 PM
minintrigue's Avatar
minintrigue
most likrely the wheel has to come off. poking the holes is no big deal. You'll never notice.
Old Apr 3, 2015 | 06:27 PM
AZdsrt's Avatar
AZdsrt
I agree, would be best to remove and reinstall the steering wheel..
Old Apr 4, 2015 | 12:16 AM
RB-MINI's Avatar
RB-MINI
Check with an alignment place to see how far off your alignment is, and if centering your wheel is outside the range of adjustment. Centering the wheel is part of the alignment process. If they tell you your wheel is so far off it needs to be re-installed, then go back to the dealer to have them correct it before getting the car aligned.
Old Apr 6, 2015 | 07:04 AM
Check the wheel, most likely they did not place it to match the bottom tick mark on the spline.
Gen 1 R50 R52 R53
JCW Leather Alcantara Steering Wheel 32300403545
http://www.ecstuning.com/Search/SiteSearch/32300403545/
See the little mark> Should line up with the mark on the spline.
Old Apr 7, 2015 | 04:23 AM
Anakist's Avatar
Anakist
Can you reuse the R53 airbag with it or do you need a new one?
How easy is it to buy the buttons for them?
Thanks.
James
Old May 11, 2015 | 06:44 AM
You will need the 3 spoke airbag, and if you have a 7/2004+ three spoke wheel the front pads and the airbag swap.
Old May 17, 2015 | 10:43 PM
Rrotz's Avatar
Rrotz
Let me just get this straight, mine is a September 2004 R53 so the current airbag in the 2 spoke will swap out directly and there is a kit with wiring to make the 10 buttons on front work? What is the right JCW 3 spoke wheel to use, can the newest 2014 model steering wheels work?
Remind me where the kit is to retrofit, there are so many sites that I forget where the JCW steering wheel and retrofit kit are at.
Old May 17, 2015 | 11:45 PM
Rrotz's Avatar
Rrotz
Old May 18, 2015 | 10:31 AM
You are in Australia correct, Think they had the two spoke go further in the 2005 year.
I know this for the US cars :
If you have the two spoke wheel and go to the three spoke,
https://www.northamericanmotoring.co...g-wheel-2.html
Wire harness for the three spoke : connection line. Airbag for three spoke ( we currently don't carry them ) and three spokes steering pads. Key pads left and right , then the center lower pad ( blank ).
http://www.ecstuning.com/Mini-2005-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Interior/Steering/
Dec 23, 2015 10:36 AM
nomar116
Aug 12, 2015 05:24 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
PatrikKN
Aug 5, 2015 09:10 PM
