Dang Drivers Door
Old Jul 9, 2014 | 05:51 AM
Luckylou's Avatar
Luckylou
Dang Drivers Door
Hi All, Just purchased a 2008 mini cooper, had it for a few days now, got aboard this morning and the drivers door won't close! Tried it a few times with no luck, but it does close from the outside?? Go figure, any ideas? Thanks
Old Jul 9, 2014 | 05:53 AM
whaap's Avatar
whaap
Shot in the dark: Any chance your seat belt is the cause?
Old Jul 9, 2014 | 06:00 AM
Luckylou's Avatar
Luckylou
You mean like jammed in the door? No, no apparent obstructions that I could see anyway..
Old Jul 9, 2014 | 06:25 AM
Did you check the door lock in the jam, it is suppose to open when triggered all the way. Then when you close it latches shut. Might be jammed ( spray it ) or broken, which is you need replaced.
#1 in the diagram.
Do you have an 2008 MINI Convertible ( Gen 1 ) or a 2008 R56 Hardtop ( Gen 2) ( newer body style ) ?
Gen 1 MINIs door locks. R50 R52 R53
Door Lock Unit - Left ( driver side ) 51200556768
http://www.ecstuning.com/Search/SiteSearch/51200556768/
Gen 2 MINIs Door locks , R56+ 51212752595 Driver side front door.
http://www.ecstuning.com/Search/SiteSearch/51212752595/
Old Jul 9, 2014 | 06:45 AM
Luckylou's Avatar
Luckylou
Thx it's a hard top.
Old Jul 9, 2014 | 06:47 AM
You are welcome. Then Follow the R56 part above and inspect the lock #1.
Old Jul 9, 2014 | 07:11 AM
Luckylou's Avatar
Luckylou
Doesn't appear to be anything broken, it shuts fine from the outside but not when your sitting in it??
Old Jul 9, 2014 | 07:18 AM
Could be still the lock or the cable. The cables and snap or stretch. The lock can break on the inside where the cable pulls the actuator. This cable connects from the inside handle to the lock. When pulled moves the door lock and then opens. is the handle/ cable is fine. then its the lock itself.
#9 Bowden Cable For Door Opener
http://www.ecstuning.com/Search/SiteSearch/51212754525/
Old Jul 9, 2014 | 08:29 AM
Luckylou's Avatar
Luckylou
Did some reading on the forum, reset the windows and now the door shuts fine.. who knew!! Thx all..
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Filmy
Sep 7, 2015 08:27 PM
F55MidnightBlackCooperS
Sep 3, 2015 04:02 PM
Southern Marylander
Sep 3, 2015 05:46 AM
Suspension Products
Sep 2, 2015 10:32 AM
