Dead AMP or blown speakers?
Old Jan 12, 2013 | 08:34 AM
supercooper53's Avatar
supercooper53
Hi guys I just got a 2004 Mini Cooper s it has the Harmon kardon stereo and I'm not sure if the speakers are blown or the amp is dead. The speakers work fine until like volume 10 ish then they sort of just start crackling. I'm leaning towards the fact that they are blown. If they are, does anyone know where I could get some tweeters / speakers replacements. I'd like to get some harman kardon replacements but would consider aftermarket as long as I could keep the factory look.
Old Jan 12, 2013 | 08:38 AM
Braminator's Avatar
Braminator
I would lean towards the amp if all the speakers crackle when the volume is up. These amps are known for failing.
Ebay for HK originals or Crutchfield for replacements.
Old Jan 12, 2013 | 08:53 AM
ZippyNH's Avatar
ZippyNH
Changing just the hk amp is problematic (to non-hk), as are the speakers....
due to the desgin, 100% must be torn out if you go aftermarket....
the amp uses linelevel speakers, the speaker impeadence is pretty non-standard, the crossovers are in the wrong places...etc....so do some research and make a choice....aftermarket ends up a gut and rewire including the head in most cases, or just swapping an amp, which while $$, does sound good st moderate volumes....depends on your needs and $$$.
Old Jan 12, 2013 | 09:19 AM
supercooper53
Soo if I was to go for an amp could I get a different amp that is a little cheaper and can just go get at best buy?
Old Jan 12, 2013 | 09:24 AM
Braminator's Avatar
Braminator
Yes and no. Zippy nailed it.
Old Jan 12, 2013 | 11:59 AM
ZippyNH's Avatar
ZippyNH
Just as bram said, reread my prior post....
short answer...replace hk with ONLY HK. Anything else reqires ALL NEW......
Old Jan 12, 2013 | 12:00 PM
supercooper53
Alright will do thanks!
Old Jan 12, 2013 | 12:14 PM
ZippyNH's Avatar
ZippyNH
short answer...replace hk with ONLY HK. Anything else reqires ALL NEW......or a good pro to sort through to try to make the frakenstein system work....
The HK system is well enginerred for moderate volumes, but as an oem radio, is VERY different in compotents, setup and wiring compared to aftermarket solutions...
Old Jan 14, 2013 | 01:08 PM
supercooper53
Turns out that its just the tweeters that are blown besides eBay does anyone where I could get some?
schr5530
Oct 5, 2015 08:28 AM
schr5530
Oct 1, 2015 05:11 PM
patsum
Oct 1, 2015 06:33 AM
silence2-38554
Sep 28, 2015 12:19 PM
