02-04 jcw vs 05-06 jcw exhaust
Old Oct 27, 2012 | 02:34 PM
burley's Avatar
burley
Is there a difference between the 02-04 jcw exhaust vs 05-06 jcw exhaust? I just bought what I thought was an 06 JCW exhaust for my 06 MCS, and it turned out to be off an 04. On some websites I see that they sell 2 versions of the JCW exhaust (pre facelift and post) for r53. On a diagram of a facelift it looks like the cat and lower exhaust are 2 separate parts.. The one I bought is one solid piece.
Anyone know the difference? Hoping mine fits..
Old Oct 27, 2012 | 02:48 PM
ACallahan's Avatar
ACallahan
Your 04 JCW exhaust should fit on your 06 without a problem, I was unaware of any change with the JCW exhaust untill 07.
Old Oct 27, 2012 | 03:02 PM
burley's Avatar
burley
If you scroll down you can see the different r53 jcw exhausts - pre and post facelift. Thoughts??
http://www.minigenuineparts.co.uk/mi..._Exhausts.html
Old Oct 27, 2012 | 03:41 PM
ACallahan's Avatar
ACallahan
Again I say there is no difference, someone else can chime in and correct me if wrong. The straight one at the bottom comes with all the JCW exhausts its known as a rezonator pipe(helps mellow the sound out) and comes after the cat. some people cut the rezonator off and just make it straight pipe after cat. to the mufflers for a more aggressive note. They may be selling the GP setup for more money because it was a limited run of JCW's and they just can, but the exhaust is not different on the JCW untill the turbos came out in 07.
Old Oct 27, 2012 | 03:46 PM
ZippyNH's Avatar
ZippyNH
the mounting bracket locations were moved slightly.....
The main reason for the change was a crimp that was added to the face lift exhausts cause the cabrio got extra bracing....the crimp allows it to clear the brace.
Old Oct 27, 2012 | 03:49 PM
burley's Avatar
burley
So will the 04 exhaust fit my 06?
Old Oct 27, 2012 | 03:50 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by ACallahan
Again I say there is no difference...
There were indeed two versions of the exhaust but they were very similar and either should work on your car.
The first had round tubing all the way back. The later had a crimp in the tube near the Y to accommodate a crossmember that was on the convertibles.
I also found that the hangers were different when I installed a later version on my 2003. Pointing in a different direction but easily fixed with Honda part 18215-SMG-E11 which is a rubber hanger that has the holes perpendicular to each other and works perfectly. Honda or Acura dealers will have them in stock.
Rich
Old Oct 27, 2012 | 04:19 PM
burley's Avatar
burley
Rich
Awesome, thanks for the info. I have a crimp in my tubing near the Y, so I must have the right facelift exhaust.
Old Oct 28, 2012 | 12:39 PM
ashchuckton's Avatar
ashchuckton
Crimp = later JCW pipes.
Minibeagle
Aug 13, 2015 10:00 AM
ASRman
Aug 13, 2015 09:33 AM
Aug 12, 2015 01:24 PM
papawhiskey
Aug 10, 2015 09:31 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
