A couple of questions
Old Oct 18, 2010 | 10:11 AM
Carole's Avatar
Carole
When I picked up my MINI, my salesman told me to put 92 octane gas in it. Is that necessary, and if so, why? Just wondering as it's almost .30 more per gallon.
Also, I'm thinking of getting the Union Jack mirror caps for the side mirrors. Do they have to be installed by MINI or are they something that can be installed myself? Also, what about the one that goes on the rear view mirror?
Thanks,
Carole
Old Oct 18, 2010 | 10:27 AM
sokolowsmd's Avatar
sokolowsmd
Hi Carole do you have a S? if so, you probably should be putting in 93 octane. As for the caps for the side mirrors you can do it yourslef; if you search for how to install them on here you should find tons of posts. Also the cap that goes on the rear view mirror is really easy to install and is something you can do yourself. The cover has double sided tape that is already applied to it. All you have to do is pull off the backing (while the cover is over the mirror) and the cover will stick. The rear view mirror cover should have directions showing this. However, I have found that you do not need to use the tape at all. Just put the cover over the mirror and it fits very snug. I really did not want to stick anything to my mirror so I figured I would give it a try. It's been almost 3,000 miles and my cover hasn't moved! My advice is apply the rear view mirror cover first withouth the tape and see how it goes. It if stays on and doesn't rattle-leave it.
Old Oct 18, 2010 | 10:31 AM
Fatherdeth's Avatar
Fatherdeth
Thanks,
Carole
Due to the high compression ratio of the engine, you have to run the premium octane to avoid potential damage to the pistons. The computer will retard the timing by way of knock sensors if you accidentally put a lower octane fuel in, but performance and miles per gallon will suffer. It's best to use premium.
The mirror caps are not hard to install, but it requires that you remove the mirror themselves to get to the screws. If you don't feel like this is something you can do, then you should probably find a local MINIAC to help you or let the dealer install them. The rearview mirror cover just snaps on over top. You can easily do that one yourself. Hope this helps.
Old Oct 18, 2010 | 01:04 PM
Carole's Avatar
Carole
No, I don't have an "S". Just the regular MINI. Thanks for the explanation. I put 92 octane in it the first time I filled it, which is considered super premium. The premium was 89 or 90. So the 92 will make her run the best then?
Thanks also for the advice on the mirrors. I'm kind of handy with tools, so first I'll see how much the dealer charges, and if it's a lot, then I'll probably give it a go myself
Carole
Old Oct 19, 2010 | 09:01 AM
Charlie Victor's Avatar
Charlie Victor
Carole -
The octane question comes up periodically; the manual for your car says something like regular unleaded will not damage the car, but 91 octane is recommended. Many people (including me) find that they get better mileage with the 91 octane fuel, so even though it costs more per gallon, you get more miles per gallon. A few people have reported that their cars actually don't run as well using regular; others have had good experience running the mid-grade gas. My suggestion to you is to try each, and see how your car responds. I'd suggest running a couple of tanks of each grade for more consistent results. You'll want to keep an accurate record of how many miles driven and how many gallons pumped; the pump receipt is how I keep track. Let us know what you find, and enjoy your new MINI!
Old Oct 19, 2010 | 09:40 AM
jcauseyfd's Avatar
jcauseyfd
Also, iirc, the compression ratio on the Justa is higher than the S.
Old Oct 19, 2010 | 10:50 AM
Carole's Avatar
Carole
Originally Posted by Charlie Victor
Carole -
Thanks, Charlie. I am getting great mileage with the 92 octane, so I think I'll just stick with it. I bought a little notebook to keep track of my mileage. so I'll see :-)) Right now, driving around town I'm getting 34 mpg.
Carole
Old Oct 19, 2010 | 11:19 AM
dwebber18's Avatar
dwebber18
Yeah just put the 92 in it, we have 93 as our premium around here and thats what I've always used. You get better gas mileage and your car is made for that. I don't skimp on gas and oil changes, no sense in saving a couple bucks now and being out a couple hundred or thousand if something breaks or dies prematurely.
Old Oct 19, 2010 | 03:20 PM
Suzanne's Chili Red S's Avatar
True, the "static" compression ratio is higher, but the cylinder pressure is much higher in the "S" due to its forced induction. All the more reason to use premium, especially in the "S".
Old Oct 19, 2010 | 05:03 PM
Capt_bj's Avatar
Capt_bj
research what "octane" means
understand what "octane" means
then you will have an informed answer to your question
Wickapedia has a decent answer and if you doubt it (as many do doubt Wick') search the web for more answers . . .
IMHO when you understand what the term means you will gain an appreciation for the manufacturer's recommendation.
If you want the bottom line - if you run lower octane than the recommended, the computers in the car "de-tune" the car to compensate. A few years ago we'd change the timing to a less efficient setting to compensate for "cheap gas". The car ran OK but we'd loose acceleration. (circa 1975 . . . .)
Old Oct 19, 2010 | 10:33 PM
BensMini's Avatar
BensMini
Welcome to the forum, well I think we have run the fuel grade debate back into the ground yet again. If you want to save some money and risk poorer performance and the chance of problems over the long haul, run regular or midgrade, if you don't mind the extra 1 cent a mile and avoiding the worries, run premium.
Alkaidovich
Jan 30, 2021 01:35 AM
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
Branto
Sep 24, 2015 04:41 AM
missinmyjeep
Aug 22, 2015 07:13 PM
Bennyboy
Aug 18, 2015 07:28 AM
