clutch went out
Old Sep 26, 2010 | 02:59 PM
ussoldier14e's Avatar
ussoldier14e
clutch went out
my clutch went out in my R56 cooper s im placin an order for a 2+ clutch tomorrow but need help finding a video on how to replace it. ive searched youtube multiple times. is it the same as any other car is there different stuff you have to remove i know a little bout cars but ive never done a clutch b4
Old Sep 26, 2010 | 05:23 PM
Porthos's Avatar
Porthos
I doubt there will be a video. Good luck that is going to be at least a 2 day adventure. I did it in my last car and it took around 22 hours. If you have access to a lift I suggest using it. The good thing is you won't have to unhook any framing to get the transmission. Oh and one last thing make sure you drain the tranny fluid first.
Old Sep 27, 2010 | 05:19 AM
ussoldier14e
o wow thanks for the help i was planning on it taking about 3 days it took you 22 hours should be to bad then and from what you said it doesnt sound like its to hard of a task but then again ive never replaced a clutch b4
Old Sep 27, 2010 | 06:15 AM
Keyser_Soze's Avatar
Keyser_Soze
If you have never replaced a clutch and are fishing around on youtube searching for an instructional video, then it might be best if you found an independent garage that services MINI's to do the job... Not trying to be harsh, just realistic...
Old Sep 27, 2010 | 06:19 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Since your replacing it now is your chance to get an OS Giken unit with a lightweight flywheel. These units seem to be bullet proof.
http://www.waymotorworks.com/os-giken-clutch-kit.html
Old Sep 27, 2010 | 09:43 AM
Porthos's Avatar
Porthos
There are a lot of bolts and a lot of torque specs that need to be done. If you do it yourself get someone that has done it and ask for their help. Even if it is not a MINI that they did at least they will have a general understanding. I tell you I will never again do it myself its too much of a pain in the *** for me and I was wrecked by the end of the weekend.
Old Sep 27, 2010 | 10:27 AM
Bigprfed22's Avatar
Bigprfed22
Not hard at all... just take your time, but definitely a no go on you tube. You will need proper torque specs and a buddy also for when you pull the trans.
All clutchs are the same principle pretty much so just removal and assembly are the things that are different.
GL
Old Sep 28, 2010 | 06:50 AM
ViperGTS's Avatar
ViperGTS
Ok.....
So, having driven a manual for the last 8 years in my vehicles, I have never had to replace a clutch.
I'm just wondering....
Why is it such a time-consuming job?
Waylen, how long does it take you to do a clutch job in a MINI?
I was thinking I could do this myself when our R53 finally needs one, but now I'm wondering.....
I do everything to the MINI (oil change, brake changes, pulley, CAI, one ball, anything electrical), so would I be able to do a clutch job myself with instructions? I am pretty mechanically inclined.
Old Sep 28, 2010 | 05:50 PM
Porthos's Avatar
Porthos
It takes so long because of the fact that there is so much to remove.
Old Sep 28, 2010 | 06:01 PM
2Miniacs's Avatar
2Miniacs
Originally Posted by ViperGTS
Ok.....
VIPER, it's not a difficult job but it is time consuming. Changed the clutch on my daughter's R53 and the first tme is the most difficult as you have to figure out how to do quite a few of the removals. You're basically removing the front end of the car and the front subframe/suspension to get to the clutch and then it's easy. The tranny removal is basically a one person job once you get to it. I think I could do one in about 8-10 hours now.
Old Sep 28, 2010 | 06:04 PM
orangecrush's Avatar
orangecrush
Yeah, just make sure the idiots at OS send you an updated flywheel with the hole for a timing tool and also instructions to let you know BEFORE you button up the damn tranny that the new flywheel is 2-3mm thinner than stock and you'll need new bolts.
Ok.....
Having pulled the engine and trans out twice in the last week, I can tell you it's not that hard, it is time consuming.
Doing it on the floor we were able to pull the engine and trans on the cradle, replace the clutch, install a OS LSD and put it back in less than 8 hours.
In all fairness though, we had the front bumper off, both headlights, fenders and axles already removed. That in itself is good for a couple of hours.
Mark
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
