02 mcs checking oil?
Old Jul 8, 2010 | 01:40 PM
Sajuuk Khar's Avatar
Sajuuk Khar
Hi everyone,
I just picked up a new to me 02 mini cooper s with 59k miles on it. Everything seems to be great with the car.
I hear a little rattle at idle from the engine, it isn't too bad or loud but sounds like lifters maybe? is this a common issue?
My real question is how do I check the oil in this car? I pull out the dip stick and I just see this yellow thing at the bottom of it with no low or full marks as the manual indicates?
Old Jul 8, 2010 | 01:44 PM
HRM's Avatar
HRM
The manual is pointing to where the low and high marks would be if they existed. (just a guess)
If there is oil near the middle, you are OK.
Old Jul 8, 2010 | 04:39 PM
Porthos's Avatar
Porthos
http://www.whiteroofradio.com/check-your-oil-again/
Good podcast by the way. Start listening.......Go!!!
Old Jul 8, 2010 | 05:22 PM
ZippyNH's Avatar
ZippyNH
A rattle at 59k...not a good sign. Try to listen hard...is it from the belt side....or is it more of a ping (from low octane fuel)? Any codes for misfires?
I might be tempted to wait till the next mini...an internal engine rattle, and an airbag light (previous posts)...it sounds like an ominous start...one tip later mini's were generaly assembled to much higher standards than the earlier cars that tended to have lots of issues...even with low miles. I'm not saying it is a bad car, but thre are lots of danger signs, so tread carefully.
Old Jul 8, 2010 | 05:47 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
You want the oil to be in the dimpled area of the stick. Preferably at the end towards the handle. Check it every few thousand to be safe. The car will undoubtedly use enough oil over the 7k to 10k interval that you will need to add some oil. Or simply change at 5k with a check at 2.5k.
Old Jul 8, 2010 | 06:15 PM
Sajuuk Khar
It seems the rattle only happens when the car is warmed up and is in neutral, when I press down on the cluth the rattle goes away, if I take my foot off the cluth in neutral it comes back.
Does anyone else have this problem? Ive read on other fourms this is a common thing and could be a sigh the gear box is on its way out, is this ture?
Ive already bought the car so Im stuck with it, but I have a 6 months waranty for the dealer, and I think the drive train is covered. I will talk to them tomorrow about this.
Old Jul 8, 2010 | 07:44 PM
ZippyNH's Avatar
ZippyNH
That sounds like a clutch rattle.....not the gearbox.
Old Jul 9, 2010 | 06:15 AM
Sajuuk Khar
It this clutch rattle something to be concerned about? Ive been doing some research and it seems like a common problem. Lots of people seems to have their clutch/flywheel or even the whole gearbox replaced and sometimes it solves the rattle and other times it doesn't.
If its not hurting anything I think I can live with it..
Old Jul 9, 2010 | 09:33 AM
Porthos's Avatar
Porthos
Remember you can over fill the oild which will cause just as many problems as not having enough.
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
ShadyCoop
Aug 24, 2015 06:05 AM
massmini03
Aug 12, 2015 11:19 AM
clintmeister
Aug 12, 2015 11:11 AM
