A couple of questions
Old Feb 10, 2009 | 06:25 AM
miniman101's Avatar
miniman101
Completely unrelated to each other as well.
1. Double shifting...whats it for? Isn't it just more wear and tear on the clutch?
2. When I get coilovers eventually. Do I really need camber plates? I know I won't be doing a lot of autocrosses or track days. Maybe just every once and a while. So are they really necessary?
Old Feb 10, 2009 | 06:54 AM
Thyodin's Avatar
Thyodin
for 1), "Double Clutching" was mostly used before Synchros. It was a way to match engine speed to transmission speed between shifts. It's not something you're going to need to worry about, since you have a modern gearbox and you're not driving a Semi-Truck. It's the upshifting parallel to heel-toe downshifting.
I don't know about 2, but I'm sure someone on here does.
Old Feb 10, 2009 | 07:52 AM
Creeve's Avatar
Creeve
No, camber plates aren't integral to coilover suspension. But if you are trying to build a suspension that doesn't simply look good but also performs well then they are the only way to have adequate adjustment of your front suspension geometry.
Old Feb 10, 2009 | 07:54 AM
OPC's Avatar
OPC
RATTUS Deserticus
Regarding question 2.
You'll probably get better responses in the "mods" forum, but the answer is maybe. It depends on:
  • How much your coilovers drop the body (i.e which coilovers and how much lower?)
  • How close to spec you want to return your alignment. Some people have been able to get back to spec without camber plates. Some like running the negative camber. There is some adjustment in the struts. YMMV.
You can always do this incrementally. Get the coilovers. Go get an alignment and be prepared to have them recommend/require plates.
Do plan on getting some rear control arms to get the rear wheels back to spec alignment. These are less avoidable.
Old Feb 10, 2009 | 12:30 PM
miniman101's Avatar
miniman101
Yeah thats what I thought. Heel and toe shifting is all a guy needs to do. I have just seen a lot of youtube videos where guys seem to think that double clutching is an integral part of driving manual.
Old Feb 10, 2009 | 01:42 PM
jonnieoh's Avatar
jonnieoh
Well, consider your source...
YouTube is full of misinformation, (in video form).
Old Feb 10, 2009 | 02:00 PM
miniguy5's Avatar
miniguy5
I plead ignorance, why is double clutching bad.... I had two previous sticks 87 chevy s10 and 94 tercel and coasted to a stop light in neutral. If it turned green I would shift into whatever gear is needed. Granted these are older cars so if anyone has info on it being bad on a mini I would appreciate it.
Old Feb 10, 2009 | 02:15 PM
Thyodin's Avatar
Thyodin
That's not exactly "Double Clutching". Double clutching would be more like while rapidly upshifting, pausing for a second mid-shift and letting out the clutch to let the engine slow down, pressing down the clutch again, then shifting into gear and releasing again. Thus pressing/releasing the clutch twice for each shift.
It just causes undue wear on your clutch plates and it accomplishes the same thing that the synchros are there for, matching engine and transmission speed.
Old Feb 10, 2009 | 03:01 PM
miniguy5's Avatar
miniguy5
.......answers that question
Old Feb 10, 2009 | 03:02 PM
miniguy5's Avatar
miniguy5
Then what I'm doing doesn't hurt the clutch I assume?
Old Feb 10, 2009 | 03:33 PM
mullman's Avatar
mullman
The technically correct answer is the less you use the clutch the less wear on its parts.
On bikes and cars I downshift as I get to the light, then have the vehicle in neutral while waiting (foot/hand on brake, obviously).
I restore vintage BMWs and can attest that holding the clutch in while waiting causes wear.
Old Feb 10, 2009 | 03:36 PM
Thyodin's Avatar
Thyodin
Nope, you're just coasting in Neutral. No problem with that.
Old Feb 10, 2009 | 04:09 PM
miniguy5's Avatar
miniguy5
Thanks guys, my dad taught me stick many moons ago and this will be my first stick in 10 years so I'm trying to remember all the details, but it is like riding a bike.
Old Feb 10, 2009 | 06:55 PM
DixonL2's Avatar
DixonL2
General rules:
Brakes are for slowing
Downshifting is for going after slowing (being in the right gear for subsequent acceleration), or slowing if your brakes fail. Period. Anything else is "road dancing" - and I do it too. It's fun, can be obnoxious (downshifting to a stop - without a sequential racing gearbox - is somewhat silly) and yep, I admit I do it, so let's not argue.
Coasting in neutral should be done with some caution in case acceleration may be needed, in which case stay in gear. Neutral coasting is/was actually ILLEGAL in some states! It's common practice, not bad for the car, and (as anything) done with care works great.
Standing still = neutral, unless "launch" is imminent.
Coasting in gear uses less gas than coasting in neutral since the fuel is shut completely off to the engine. Yes, that's true - and a sensitive butt dyno can even feel the point when the fuel kicks back in just as the car speed and engine speed match up. Yes, it causes some (negligible) wear on the powertrain compared to coasting in neutral. No, I don't really care, it's just interesting.
Enjoy! The Mini, driven well, is a very rewarding road dance partner.
Old Feb 11, 2009 | 05:09 AM
IzzyG's Avatar
IzzyG
Camber plates aren't a "necessity", rear lower control arms are-when the Mini is being lowered that is. Unless the drop is severe, the front end won't see much change in camber when lowered. The rear however, will be obvious.
Alkaidovich
Jan 30, 2021 01:35 AM
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
Branto
Sep 24, 2015 04:41 AM
missinmyjeep
Aug 22, 2015 07:13 PM
Bennyboy
Aug 18, 2015 07:28 AM
